help please- horn not working
Old Apr 7, 2004 | 02:44 AM
matts94f150's Avatar
matts94f150
94 f150, 170,000 mi. got the truck about 4 months ago, with no working cruise control.
Today i wanted to honk the horn, but it wouldnt honk.
Checked the fuses with a circuit tester, seems okay, dont hear anything from the relay, checked with spare relay, no noise from relay or horn
i've been seaching and found a bunch of clock spring posts, and when i turn the steering wheel, i hear something rattling inside. could that be the problem? if not what other things should i check?
if it is, will the removal of the steering wheel with air bag be a problem?
what tools would i need?
any help would be greatly appreciated.
Old Apr 7, 2004 | 03:15 AM
laka's Avatar
laka
Sounds like you've identified your problem. I'm not familiar with the air-bag steering wheel, but somebody will tell you how to go about it. Chances are you'll be able to fix your cruise-control at the same time.
Old Apr 7, 2004 | 01:44 PM
LoosMaster's Avatar
LoosMaster
Exclamation
I would invest in a Haynes or Chilton manual before removing steering wheel. I had to change the horn button on my Mustang which required removal of the wheel. If I remember, disconnect the battery first. When you remove the wheel, you have to short the SRS plug to prevent it from firing. Also, don't lay the wheel face down. If it does accidentally fire, it will become airborne. Just be careful with this thing.
Old Apr 7, 2004 | 01:59 PM
LoosMaster's Avatar
LoosMaster
Tools - Other than general, you'll need a "duck foot" type puller. If you're going to buy one get the large kit, works in alot of places. The one just for the steering wheel is just for that. Also, a large wrench or crescent for the shaft nut, if you have sockets that large would be better. Hold the steering wheel while turning the nut c/c, don't use the steering lock, you can possibly snap the pin if the nut is too tight. Mark the shaft and wheel so you can put in on the same way.
Old Apr 7, 2004 | 03:17 PM
Slade901's Avatar
Slade901
Don't forget to actually test the horn itself by directly connecting it to the battery with some long wires to see if it even works in the first place.
Old Apr 7, 2004 | 06:13 PM
matts94f150
horn works when you wire directly to battery. How do you short the srs plug to prevent the airbag from firing?
Old Apr 7, 2004 | 06:31 PM
LoosMaster's Avatar
LoosMaster
Don't have my truck manual handy but Stang manual says to disconnect neg side of battery and wait 15 minutes, if disconnecting Positve, ground it and wait 1 minute. The airbag has a secondary power supply(capacitor) to fire the bag if battery is damaged in accident. Disengage the driver air bag module connector and attach a jumper wire to the air bag terminals on the clockspring(wiring harness). If you have a passenger side air bag, you'll need to disarm it also. The Stangs plug is behind the glove compartment. Again, I would recommend you buy a manual for your year truck.
Old Apr 7, 2004 | 06:55 PM
JimmyDee's Avatar
JimmyDee
I had intermittent horn operation and simply cleaned the switches. Mine was a '96 air bag E250 - I'm not sure whether yours is like mine: air bag in the middle, two buttons "under your thumbs".
Once the air bag cover comes off you will find an electrical connectior for the air bag assembly. All the literature has lots of warnings about not pointing it at yourself. (It's hard to imagine one firing out-of-circuit, but some are equipped with a capacitor which, when charged, sotres enough energy to make it go bang. I'd guess the chance of a firing is greater if you hook it up to a hot system. Disconnect the battery!) Four bolts through the back of the steering wheel attach the air bag.
You should be able to borrow a steering wheel puller from AutoZone. The switches are pretty simple and shouldn't cost much. Left and right sides are different.. Mine were simply dirty and a bit of contact cleaner worked.
PITA to get to the switches without removing the wheel.
Old Apr 7, 2004 | 07:05 PM
northsea's Avatar
northsea
Same horn and cruise control problem.
I have the same problem with my 94 F150 no horn no cruise control and the airbag dash light will light three times then wait and light three times. Let me know how you solve the whole problem.
Question, how do I ground the + battery cable?
ScottSC
Old Apr 7, 2004 | 07:26 PM
LoosMaster's Avatar
LoosMaster
To ground the Positive cable, just attach it to the frame somewhere it has clean metal, i.e. no paint. This is after you have disconnected it from the battery.
Last edited by LoosMaster; Apr 7, 2004 at 07:27 PM. Reason: Possible misinterpetation
Old Apr 7, 2004 | 07:30 PM
LoosMaster's Avatar
LoosMaster
I had the same problem on the Stang's air bag, found out it was one of the triggers behind the bumper, Ford wanted $175 for it. I disabled the dang thing. They told me that a bad trigger could cause the bag to fire inadvertently.
Old Apr 10, 2004 | 11:09 AM
northsea's Avatar
northsea
Air bag light
if the trigger is disconnected is the air bag out of commission?
ScottSC
Old Apr 10, 2004 | 11:13 AM
northsea's Avatar
northsea
No horn no cruise control
I have been monitoring this thread. I have not heard any rattling as I turn the wheel and have also checked the fuses.
How do I test the horn by connecting to the battery?
scottsc
Old Apr 10, 2004 | 12:00 PM
LoosMaster's Avatar
LoosMaster
scottsc
Unplug the connector to the horn, put a wire from terminal to Pos battery post. If it works, she'll blow.
ScottSC
From what the Ford tech told me, yes. But I never bothered to look at the schematics to be sure.
Old Apr 10, 2004 | 10:26 PM
charredskin's Avatar
charredskin
howdy
Howdy folks, I noticed a few of you are having similar problems... I too had this problem a while back. First thing to go bad in my truck was the cruise control... then about a month or two later the horn stopped working. Turned out to be the clockspring. I think I paid like 165$ or so.. cant recall for sure.. had to go to the Dealership though... grrrr
I was just wondering, are any of you getting the 3 - 2 flash from the airbag light on the dash? If so I would say it is definately clockspring.... steve83 taught me good on that one! thanks steve!
The job was pretty simple once i got the right steering wheel puller
I think the hardest part out of all of it was getting the plastic parts all back on the right way... then again im like a bull in a china shop when working on anything.
