help please- horn not working
Old Apr 10, 2004 | 11:38 PM
Bushwacker00's Avatar
Bushwacker00
Hey,
I just got my truck about a month ago my horn doesnt work either, I push the horn in and i hear a ticking coming from somthing near the fuse box but none of my fuses are bad.... if anyone could give me a pointer that would be great i dont kno anything about them yet....
Old Apr 11, 2004 | 02:20 PM
charredskin's Avatar
charredskin
Sounds like you horn relay has gone bad bushwacker... Check the fuse panel for a good sized square or round block that plugs in there
Old Apr 11, 2004 | 11:12 PM
Bushwacker00
Hmm
I have a relay 1 and a relay 2 switch, and then also i have a few more square lookin jiggers in there lol...
Old Apr 12, 2004 | 12:10 AM
charredskin
you oughta try takin' them out one at a time and see which one gets rid of the clickin' when you honk...
Old Jun 6, 2004 | 07:47 PM
Henlabs's Avatar
Henlabs
More Horn/Cruise Control Responses
I just repaired my '95 Windstar that had the same problem, no horn or cruise control. It turned out that my cruise control servo module connector was defective. Two pins in the connector were burnt. It turns out that the horn circuit is grounded through these pins too. I replaced the cruise control servo module and it fixed both problems. The Haynes manual I have showed me how to take ohmmeter readings through the cruise control connector to determine if the cruise control switches and clocksprings in my steering column were OK without taking my steering column apart. Hope this helps someone.
Old Jul 24, 2004 | 11:28 AM
ebaker2003's Avatar
ebaker2003
i have a 94 F150 with 176,000 miles on it and my horn doest work either..stoped working at 170,000 aslo..check the fues and it was fine...
Old Jul 24, 2004 | 11:31 AM
ebaker2003's Avatar
ebaker2003
the f150 has never had crusie control so its just the horn..thats not working for me
