Reverse Aid Sensor problem
Old Feb 19, 2005 | 07:38 AM
satcom40's Avatar
satcom40
I got it Online at Beach Audio the Crimestopper sv-5800pk/2 plate cam. Got it today now just have to insstall it, but it's cold outside Low 30 today.
Old Feb 19, 2005 | 07:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by 3.8vsix
I have a 04 f250 6.0, I have noticed my reverse aid sensors is not working right when it is cold out. It will beep solid like something is right behind me but there is nothing there. When it warms up outside it is fine. Have any of you guys had this problem?
Thanks!
Travis.
Check this out...when you come back
https://www.ford-trucks.com/forums/s...d.php?t=325000
Old Feb 21, 2005 | 01:05 PM
GoblesKen's Avatar
GoblesKen
Traveling snow covered roads buries the backend in that white stuff and then sensors can not see through it. Thunk it may have buried a small car while at it.
Old Mar 19, 2009 | 02:56 PM
Bay Boy's Avatar
Bay Boy
Originally Posted by Fordtech1
Cases where the RSS/FSS give warnings but nothing is within range of the vehicle sensors, or give warnings for three (3) seconds then ceases, the occurrence may be due to any of the following reasons.
BLOCKED/CONTAMINATED PROXIMITY SENSOR SURFACE:
Proximity sensor surfaces may be covered with snow, ice, dirt or mud. There is a gap between the sensor membrane and its plastic housing that must remain clear (Figure 1). If this space is contaminated with any foreign material the system may sound a continuous tone or intermittent tone. The sensor surface can be cleaned by a high pressure water spray.
SIDE COVERAGE SENSOR:
There is side/rear coverage that extends approximately 46 cm (18 inches) perpendicular from the side rear fascia. Side coverage is a desirable feature in a parking situation where the vehicle is involved in a very tight turn with little rearward movement, or where the vehicle is backing parallel to a large, extending obstacle such as a garage wall. If there is no encroachment between any of the outer sensors and an obstacle, then the warning will sound for three (3) seconds and cease. If vehicle or the obstacle begin to move closer to each other, then the warning will begin again. Obstacles within 25 cm (10 inches) of the fascia will always be reported with a continuous tone. This is considered normal operation.
ABNORMAL ROAD SURFACES:
The RSS/FSS may give warnings due to certain road surfaces with surface projections such as rocks, broken pavement, unplowed snow covered roads. This is considered normal operation.
OTHER POSSIBLE CAUSES:
Very wet weather conditions, such as mist, frost or snow may provoke occasional warnings. The system may detect liftgate while open and certain trailer hitches and/or bicycle racks. External ultrasonic noise may be detected (high velocity air, machinery). This is considered normal operation.
Clean proximity sensors with a dry shop towel, and if required wash with water or a high pressure water wash if necessary to ensure that the membrane gap is free of any dirt or contamination
My trucks dash lite is on all the time and no warning sounds.
jawdoc
Sep 7, 2012 09:37 AM
CaptainIPSC
Jun 29, 2012 03:02 PM
JoeG112
Nov 13, 2011 09:27 AM
tjc transport
Electrical Systems/Wiring
Jan 5, 2008 05:01 PM
