Rag Joint Replacement
Old Apr 6, 2004 | 09:53 PM
offroaderone's Avatar
offroaderone
Got a 68 F100 with a destroyed rag joint. Is replacing this thing a complex task, or easy? Any suggestions on a new one? Looks like the replacement catalogs I have aren't cheap. Thanks
Old Apr 7, 2004 | 09:05 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I replaced them before how are your cab corners . I loosen the column and let it lay on the seat unless you have help holding it take out two bolts under dash. I get mine at the parts store ,there are some that are made better than others i look for the ones that have the bigger pin to column fit.
P.S. If your cab corners are bad and you cant get them replace now you better get two because you will be doing it again!
Old Apr 7, 2004 | 09:50 AM
offroaderone
Cab Corners
Thanks, Cab mount on drivers side is toast. Is that what wore out my rag joint?
Old Apr 7, 2004 | 05:48 PM
Pro-Street/StateTK
Yes the rag joint is mounted to the steering box which is mounted to the frame soild the cab moves up and down and wears it out . o yeah i for got there is a clamp at the fire wall ( under the hood) it has one more small bolt to take lose.
Old Apr 7, 2004 | 09:38 PM
offroaderone
Thanks! Any parts stores to look for, or should I quit trying to be cheap and just order one?
Old Apr 8, 2004 | 09:04 AM
Pro-Street/StateTK
Well i for got the most important thing . Welcome to ( FTE ) we have so many different stores here i would just shop a round . Also take a look under the hood of a truck that has one with the small pins that dont fit the column very tite get some one to rock the steering wheel back and forth you will see the play . One of the stores here at ( FTE ) may be of great help on this!
P.S. you may also check in to replacement cab corners .
Old Apr 8, 2004 | 12:40 PM
Syntheglass's Avatar
Syntheglass
Does anyone have a pic of the rag joint cause I think mine might be torn but I don't know exactly what it is.
Old Apr 8, 2004 | 09:31 PM
baitmaster's Avatar
baitmaster
rag joints vs u-joints
My 4 wheel F-100 has a u-joint instead of rag. Have a needle bearing u on order. Should get rid of the play in it. Hope the new one has a zerk fitting on it.
Mercmeister
Sep 2, 2025 11:50 PM
badasssapper67
Feb 21, 2017 09:44 PM
jamesg139
Jul 23, 2013 02:15 PM
MUFUNGO JONES
May 28, 2012 05:12 PM
truckco
Dec 18, 2003 08:27 AM
