Problems with Built-in Compass
Old Apr 6, 2004 | 08:50 PM
cobrah's Avatar
cobrah
Question Problems with Built-in Compass
I have a 97 Ford Expedition 4x4 E.B. that has a compass that reads the same all the time N.E.
All the other data reads accurate, "fuel amount", "mpg" , etc. does anyone know if the compass has a directional device say under the hood that may be stuck?
I have activated the re-set with no results, maybe I'm doing it wrong...I think something has to tell the compass in what direction the truck is heading.
I would appreciate any feedback
Cobrah...
Old Apr 6, 2004 | 08:58 PM
King Triton's Avatar
King Triton
When you hit reset,does it go into calibration mode?
Old Apr 6, 2004 | 09:47 PM
cobrah's Avatar
cobrah
Unhappy
If I hold the reset in the screen clears and several fast flashes of non-ledgeable garb is shown and then returns to where I have it set.
It was working perfect until I let a mechanic do some work for me, when I got the veh. back my compass lost it's direction...
That's why I think the compass gets it's reading from some signaling device planted in some hidden area. I have looked into the area where the screen is and all that's there is circuit boards.
The small box beneath the screen that has the reset is the same way.
Ford say's "we will fix it for $300.00 plus labor"...
cobrah...
Old Apr 6, 2004 | 09:55 PM
MisterCMK's Avatar
MisterCMK
I believe that there is a procedure for re-setting the compass in the owners manual. Its worth a look.
Old Apr 6, 2004 | 10:01 PM
King Triton
did you get an owners manual,I am trying to remember 97 in my head,but it needs calibration too I think,I can tell ya that on the newer ones,and ya your gona laugh and think I`m pulling your leg,but I`m not.when we calibrate a compass we have to take the vehicle out into the open,and slowly drive in a circle,a couple times until it finishes calibrating itself,I cant tell ya how many salesmen have come out and asked me if I was lost!
Old Apr 6, 2004 | 10:50 PM
cobrah's Avatar
cobrah
Post
Sooo tell me... do I push the reset while driving in a circle? You see, mine resets in about 3-5 seconds.
I have no manual, and I don't remember the astronomical amount Ford say's they will sell me one for...it was in excess of $80.0
At any rate I will try your valued information, after all what do I have to loose? ( drivers license? )
No..I think you are on the up and up about this and I'm gonna try it!
cobrah
Old Apr 6, 2004 | 10:51 PM
MisterCMK's Avatar
MisterCMK
I can take a look at my manual tomorrow, since its getting late and let you know what it says
Old Apr 10, 2004 | 09:30 PM
cobrah's Avatar
cobrah
Will Ya?
I would appreciate you looking for me if you will...
Thx. cobrah
Old Apr 10, 2004 | 10:20 PM
HomerWinzlow's Avatar
HomerWinzlow
The compass display is only the display. The compass has a separate module mounted under the rear view mirror, about a 2 inch by 2 inch box. If its unplugged it wont work. If its a bad module you can replace it for a lot less than 300.00 plus labor. The display might cost that much but its not the problem.
Old Apr 10, 2004 | 11:56 PM
MisterCMK's Avatar
MisterCMK
I'll check in the morning
Old Apr 11, 2004 | 07:10 AM
cobrah's Avatar
cobrah
Thx guys I realy appreciate your feedback, maybe I can get the thing to work afterall.
cobrah
Old Apr 11, 2004 | 04:35 PM
cobrah's Avatar
cobrah
Talking Thanks to all for imfo...
And a special thanks to "KING TRITON"...here is what I did!
The re-set is on the box on the mirror, if you look close you can see the tiny hole for this.
I used a larger paper-clip that fit the hole and was easier to hold while driving.
I went to a vacant lot and started going counterclock in a circle at a moderate slow speed. (20-30' dia.circle)
I inserted the clip and held in the reset until a small display read "cal".bottom right hand corner.
I continued to circle (releasing the reset) and all of a sudden the display started doing it 's thing The cal. mode I guess means callabrating when you see this be sure to let go the reset or it will recycle.
This process probably took 5 min. with my error's included!
Maybe this will help those who think their compass is broken like me. And ya know what, I got to thinking Ford Place would have probably done the same thing and put the $300.00 in the bank... Ok, sorry about that "I take it back"
cobrah
Old Apr 11, 2004 | 04:46 PM
King Triton
well,at least you didnt get the "run around"from the cops.
Old Apr 11, 2004 | 05:01 PM
cobrah's Avatar
cobrah
Thumbs up
Yea, your right no cops... Oh, I wanted to add this to. I tried this on a adverage country road and it didn't work, ya gotta be going in a circle like the KING said!
cobrah
GLC
Nov 3, 2015 05:54 AM
bmbrdfrt
2004 - 2008 F150
Aug 19, 2010 01:12 PM
kliney9016
Sep 2, 2007 05:15 PM
cobrah
Oct 25, 2004 08:07 PM
cobrah
Aug 21, 2004 05:05 PM
