300 to 351M
Old Apr 6, 2004 | 10:23 AM
77300i6's Avatar
77300i6
300 to 351M
hi, my 77 F150 4x4 has a 300 inliner. this engine came with no emissions save for the PCV. I know this because the decal on the valve cover reads non-catalyst. my question is if i decide to swap in a 351M will i need to put emisson devices on as well,even though the truck never had any? Also my current bellhousing will not work correct? It has a NP435 tranny. I've heard that the 302/351W will mount up, but i not interest in those engines. I used to own a 78 F150 4x4 w/ the 351M and i loved the power this engine had,though there's always room for more power. any help would be profoundly appreciated.
Old Apr 6, 2004 | 10:44 AM
460powerhouse's Avatar
460powerhouse
check your state laws some the truck only needs what it came with originaly and some say the engine going in needs what it came with originaly
Old Apr 6, 2004 | 11:26 AM
beartracks's Avatar
beartracks
I would think the engine would be OK since it was offered by the factory. The bell housing is the wrong one I think. I'd go up to the 400 if I was going to do it. The weight of the vehicle determined it was "excempt" not the engine.
Old Apr 6, 2004 | 02:04 PM
jpb222's Avatar
jpb222
I would go to a 351 windsor if I were you.
I have a 79 with a 351m in it (low mile great running engine) it is in front of a c6 and is bone stock
I also swaped a 351w into my 76 and it will run circles around the 351m in my 79 and parts are easy/cheap to buy for it. Granted, it does have a cam in it but this truck is a 4x4 which adds a considerable amount of weight.
Old Apr 6, 2004 | 03:19 PM
77300i6's Avatar
77300i6
thank you everyone for your replies. I just learned today a friend of mine may be buying a 75 ford F350. It has a 390 V8/4 speed that runs. He is only interest in the dump bed on it. any thoughts on the 390? I would have all of the parts necessary for the conversion from the donor truck. I would have to use the donor tranny as well, correct?
I don't know it it's a 4x4, does it matter?
Old Apr 6, 2004 | 04:08 PM
jpb222's Avatar
jpb222
All you should need to do to put in the 390 is to use the 390 bell and move your motor mount perches over to the next set of bolt holes in your frame.
there may be some small things to address but nothing major.
Old Apr 6, 2004 | 05:11 PM
Indybroncoman's Avatar
Indybroncoman
Since you liked the 351M so much, why not build a 400? You can get great torque out of them from just a new intake manifold, aftermarket cam and a 4bbl carb. Nothing against the 390, I'm just a 400 fan, especially after owning a built one for a number of years now.
JFlom77
WTB - Parts & other
Oct 5, 2013 03:59 PM
rh428wf
16
Sep 11, 2010 07:43 AM
77FordDW
Engine Swaps
Nov 11, 2008 07:25 PM
cbracing17
Engine Swaps
Oct 3, 2005 07:37 AM
birddog25
Apr 17, 2003 03:23 PM
