Cooling Issues update...
Old Apr 4, 2004 | 02:57 PM
Ratsmoker's Avatar
Ratsmoker
It seems as if my flex-a-lite 150 is doing its job very well. I can set in drive and even bring the RPMs up to about 1400 with the brake on and the tranny cooler and engine stay cool. Never get above the 195 degree mark where I set the thermostat. With the flex fan and no shroud like I was running I would have a locked up motor doing what I just did.
I did notice while making the burnout video that my temperature spiked quite quickly when I was on the gas hard. It only made it up to about 220 or so but as soon as I let off the gas it cooled right back down real quick like. This tells me that the radiator coolant is staying cool but the water pump is not keeping up. Its not a problem that is going to hurt anything really but an edelbrock water pump is in my near future. I don't know if I will replace anything before the FE nationals though. I have the rest of the summer to tinker with it.
Old Apr 4, 2004 | 05:48 PM
gtex's Avatar
gtex
I was just about to put my fan through the real check when the rest of the motor went south. I finally got the AC compressor mounted and charged up. I don't recall it running warm on the way home from the recharge. But I was more concerned with the really poor running.
pushrods are here. Erson sent the wrong adjuster studs/nuts, so I'm waiting for those.
I think I'm going to pull the motor, disassemble and check the bearings and cylinder bores. If I don't find anything horrific, she goes back together without the lash caps. I'll check the geometry and go again...
Old Apr 4, 2004 | 07:00 PM
Ratsmoker's Avatar
Ratsmoker
Are you going to have the scratched cylinder sleeved or just run it as is??
Old Apr 5, 2004 | 07:49 AM
gtex's Avatar
gtex
I don't think I'll be doing any re-sleeving. I need to see if any of the other cylinders are scratched as well.
I'm hoping I can just clean out any particles in the rings/cylinders, then maybe smooth out the one cylinder a little (just a lite sanding of the scratch) and run it. If I have to get it machined, can I just run larger rings or something? I guess I could run one larger piston and have it balanced ??? It's all new to me.
First, I need to pull the motor, and I've had little motivation to do that.
Old Apr 5, 2004 | 07:55 AM
Ratsmoker's Avatar
Ratsmoker
You have to run the same size holes in all 8 cylinders. If you do anything you can have it honed out. You may get a away with this. You can't buy bigger rings for your pistons. They will be the same. Don't use sandpaper on the cylinder walls. It will do more damage than it looks like it is doing good.
Old Apr 6, 2004 | 01:51 PM
William's Avatar
William
Lash caps? WTF? Is that what caused the mess in your engine? Where did you get lash caps? I would tear that engine down, clean everything and start with new bearings, polished crank, new rings and so on. The damaged cylinder will likley require an over bore. You may sleeve it to keep the pistons you already own or do another block. I have never seen lash caps on an FE. Inless I did and then forgot! Rat you going to the Nats? Driving the Ford? I'll buy you a beer if you do.
Old Apr 6, 2004 | 03:30 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Rat doesnt Drink anymore??? since they invented the Funnel...JK:} Russ
Old Apr 6, 2004 | 09:40 PM
gtex's Avatar
gtex
I don't know what caused the failure.
probably poor choice of equipment and bad design by the engine designer :-)
Consider where he get's most of his information..............
Old Apr 7, 2004 | 02:37 AM
ZombieSlayer's Avatar
ZombieSlayer
gtex,
Hey, it could be worse...just look at my poor 352
http://www.thunder65.com/images/temp/eng1.jpg
Old Apr 7, 2004 | 02:54 AM
Torque1st's Avatar
Torque1st
Posting Legend
Where did you get that 352? From a boat??? -hehe
Gtex- You can hone a single cylinder to remove a slight scratch, maybe 5 thousandths or so. Take the piston to a machinist and have it knurled. Get a new set of rings. This is a poor-boy fix but it will run a while. Racing it is kind of up to you tho...
Old Apr 7, 2004 | 04:23 AM
ACESN8S's Avatar
ACESN8S
Torque- You should have seen the 352 I took out of my old 66. The crack started between the first and second lifter bores, and proceeded in an arch to 1/4 " below the deck (between the two center cyl's) and then back down to between the seventh and eighth lifter bores.
The crack had pushed out to 3/8" at the top of the arch.
Yes, I drove the truck up onto the trailer when I bought it.
When I pulled the motor, I drained 7 gals. of chocolate shake out of it.
The FE is a great motor, but if you don't have anti-freeze in it in below freezing temps, mother nature may make you pay for it.
Old Apr 7, 2004 | 06:08 AM
Ratsmoker's Avatar
Ratsmoker
Hey William! I will be there as far as I know. Something huge would have to come up between now and then. The truck will be with me too. I'll be in the race. We definitely need to have a beer.
Old Apr 7, 2004 | 09:52 PM
biz4two's Avatar
biz4two
Ratsmoker - I think you're right about the water pump not being able to keep up. I use the Edelbrock and it has worked great! I get excellent flow because I have not seen the temp gauge shoot up quickly. I am using a 50/50 mix in my aluminum radiator w/ over-flow bottle and dual electric fan #295. Of course I will see how my setup works this summer. I did the conversion/install last fall when temp's had already started to drop.
I'm looking forward to those 95° days... ...well maybe not since I don't have A/C...
Old Apr 8, 2004 | 12:24 AM
jimshaver's Avatar
jimshaver
hey biz ALL vehicles have A/C... on some you have the push button type on the rest you have the 255 style A/C
Old Apr 8, 2004 | 08:10 AM
rusty70f100's Avatar
rusty70f100
I thought it was 275?
I tried out the air conditioning yesterday. Worked great. I just had to put a little coolant into it though, some always leaks out over winter.
z2896
Jul 10, 2013 09:17 AM
thekingofcows
Offroad & 4x4
143
Jul 31, 2012 04:49 PM
Rusty_S
15
Jul 25, 2009 06:34 PM
paulcooper1969
Apr 28, 2007 01:13 AM
Overfences
17
May 6, 2002 02:16 PM
