I went to leave tonight, and when i turned the lights on the dash just flickered and the headlights didnt come on. I jiggled the know a bit to see if that helped. Then the lights finally came on but they would kind of flash or pulse whether the engine was running or not. It fires right up and the dome light works fine. Also when the lights are flashing there is a ticking noise that sounds like inside the dash, kind of like when the four way flashers are on.
I think too that it may be the switch, that seems to be where the sound is coming from. This mornig, i tried it, and there was no problem at all. I have not driven the truck so, if it were a short it should still be doing it?
Yep, replaced the switch with a new one from NAPA for $23. Now I also know why the interior light didn't come on with the ****, but only with the door.
Mine comes off with pressure applied pulling back on it. then you need to take the dash apart and unscrew the nut the holds the switch in place, replace it, then reverse the procedure. Cake
