Sponsored by: Kumho
Pulls Badly To The Right
Old Apr 13, 2004 | 05:39 PM
passady's Avatar
passady
I replaced the hose on the right side, but still no luck. It still pulls right (and occassionally left as I found out today) Basically it's turning into a toss up for what will happen when I step on the breaks. I'm quickly become afraid to drive. The break lines look good, the passenger side hose is new, the calipers are both new, pads are new, any other guesses?
Thanks!
Old Apr 13, 2004 | 07:47 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Thanks!
If you have all the other bases covered, I'd replace the drivers side brake line (hose). It could be expanding under braking causing the other side to get more pressure.
Old Apr 15, 2004 | 02:22 PM
fordberg's Avatar
fordberg
If it's going from side to side randomly then maybe take a look at the steering. Upper ball-joint could react differently depending on road crown.
Old Apr 15, 2004 | 05:57 PM
flat black beast's Avatar
flat black beast
I had the same problem and just welded a crack in the steering box to frame bracket. Now it handles mint
Old Apr 15, 2004 | 09:24 PM
passady's Avatar
passady
The ball joints look good to me, i can hardly get them to move.
What would I look for in the steering? It's definetly got some play in it, but I can't see anything move when I turn it. Where should I be looking?
Old Apr 16, 2004 | 05:53 AM
brownfoot's Avatar
brownfoot
lift the front-end of the truck off the ground and support it by the frame so that the wheels and suspension have no weight on them
check the 'play' in the steering and suspension by holding the front tire at 3 and 9 o'clock positions and moving it as if you were turning right then left
this should let you feel any looseness in the steering....everything should be tight and smooth and if you feel any looseness or "slop" , you should be able to see where it is
as for ball joints, hold the wheel at 6 and 12 0'clock and try to pull the bottom of the tire out an in and the top of the tire out and in and the same time, there may be some movement, but not any 'clunking' or looseness
this should let you at least see if there seems to be some problem with the steering/suspension
Auburn08
Feb 21, 2015 04:58 AM
Ghadaz
Dec 21, 2013 01:02 PM
Hadrian86
Sep 9, 2010 09:24 PM
Fomhoire
18
Jul 6, 2007 08:07 PM
Low70Ford
Sep 10, 2006 08:47 PM
