Aerostar Ford Aerostar
Greasing the Aerostar?
Old Apr 3, 2004 | 06:36 AM
babygherkin's Avatar
babygherkin
Question Greasing the Aerostar?
I have a 94 Aerostar, 3.0L passenger van (we call her Ginger). Since we've been doing our own oil changes, we've been wondering if there are any places in the undercarriage where we should be using the grease gun. I can't find any mention of lube locations in the useless owner's manual or in the Haynes manual. She has developed some rather worrisome noises in the rear (don't we all, after a certain age?) I thought we should rule out the obvious problems, such as a possible lack of grease, before assuming the entire suspension is about to drop off.
She has been and still is a wonderful vehicle (110,000 miles) and has never stranded me roadside unlike my previous Ford, which shall remain nameless...
Old Apr 3, 2004 | 12:02 PM
xrayjock's Avatar
xrayjock
She probably has at least grease fittings on upper ball joints. The other suspension parts are probably grease free.
Old Apr 3, 2004 | 03:12 PM
Beast12's Avatar
Beast12
Check your tie-rod ends and Universal Joints as well. I grease my truck every oil change. Good luck!
-Matt
Old Apr 5, 2004 | 09:49 PM
rebocardo's Avatar
rebocardo
Most likely with 100K it is the rubber for the sway bar being worn out.
Old Apr 5, 2004 | 10:28 PM
lasher's Avatar
lasher
if yours is like mine the noise from the rear end is from the upper control arm bushing.
it is rubber against steel rubbing. i think because the rubber is old and hard it makes noise. you can not replace it because ford does not sell the bushing. you have to buy the whole upper control arm. this noise does not hurt anything except the driver listening to the noise. i have heard spraying silicon spray on it helps. i have checked alot of aerostars that do this. you can tell by jumping up and down on rear bumper.
the other thing is to check for loose shock absorbers. mine were loose and made all kinds of funny noises.
Old Mar 28, 2005 | 09:38 PM
Plexter's Avatar
Plexter
Thumbs up Greasing the Aerostar
Hello.
I have a 1995 3.0 rwd shortie and I grease the outer tie rod ends, upper and lower ball joints (her name is Albie)
Old Mar 29, 2005 | 10:04 AM
aerocolorado's Avatar
aerocolorado
In addition to aforementioned fittings, if the previous owers replaced the driveshaft universal joints, the replacement joints MAY have grease fittings on them. Some replacements do and some don't. You have to spin the driveshaft by hand and inspect both sides of each joint to find the fitting. While doing this, see if there is any play in the U-joints. Any detectable movement could also account for the noise you experience.
Y2KW57
30
Oct 26, 2020 11:33 PM
flowney
Aerostar
Oct 28, 2015 05:20 PM
Mikeman
1978 - 1996 Big Bronco
Nov 6, 2014 12:06 AM
tapia2431
Aerostar
21
May 7, 2007 08:18 AM
eclectix
Sep 4, 2003 05:39 AM
