fuel pump or selector valve
Old Apr 2, 2004 | 11:24 PM
russell13's Avatar
russell13
My 85 f250 acts like it is running out of gas when I switch tanks it runs fine for about 30 seconds then start all over again. Is this the fuel pumps or the fuel selector valve? I have replaced the fuel filter. I need help!
Old Apr 3, 2004 | 04:06 AM
Ford_Six's Avatar
Ford_Six
Is this a 460 with the electric fuel pumps, 302 efi, carbed?
Old Apr 3, 2004 | 07:23 PM
russell13's Avatar
russell13
460 with electric fuel pumps in the tanks. electric fuel tank selector valve
Old Apr 4, 2004 | 01:07 AM
Ford_Six's Avatar
Ford_Six
It's probably a buildup of crud in the tanks, or maybe the little piece of foil from additive bottles. I would get a five gallon gas can, disconnect one of the fuel lines, either front or rear, and then jumper that pump on. If the flow remains steady, it could be a problem with the valve, but if the flow slows, there probably is something in the tank plugging the pickup.
Old Apr 4, 2004 | 03:09 AM
Washawnna's Avatar
Washawnna
Check the switch in and behind dash if this continues to be a problem.
