94 ford exploror...need help!
Old Apr 2, 2004 | 08:15 AM
jhoyle615's Avatar
jhoyle615
replaced the fuel pump relay, going to try the ecm relay. We have tried knocking on the tank no luck...gonna try the paper clip test today or tomorrow depending on when brother can get here...just want my baby to start again! Thanks for all the help...will let ya know how all this goes...
Old Apr 2, 2004 | 01:38 PM
jhoyle615's Avatar
jhoyle615
OK all of u who helped me out with this problem THANK U!!!!!!! Went to Ford this morning bought a new EEC relay ( $6.35) came home put it in and Truck turned right over!!!!! YEAH!!!!! I couldn't believe it, i turned her back off and back on again like 10 times before i believed it..lol....SO my baby and i are back on speaking terms....Thanks again for all of your help...who woulda thought i had a mechanic telling me to try this and try that...and i fixed on myown with the help of all of u....
Old Apr 7, 2004 | 04:30 PM
rburtz's Avatar
rburtz
I just had (am having) this same problem. Replaced fuel pump relay, worked for 3 days. Got home tonight and could not restart after solving another problem. I tapped the EEC relay and heard a click and heard the most beautiful whirr out of my fuel pump. I am going to replace the eec relay in the morning. Store out of stock tonight, but will have one mid-morning. I hope this works, if not, I may just shoot my 94 Explorer.
Old Apr 10, 2004 | 01:43 AM
2004supacrewlariat's Avatar
2004supacrewlariat
Put some Dielectric grease on the terminals. First time I replaced the realy I had a stretch with no problems. They came back. I used dielectric grease in the sockets before putting the relay back in. No problems now for about two years.
Old Apr 10, 2004 | 02:51 AM
jclj2003's Avatar
jclj2003
i had the same problem with mine it was the ecc relay but mine was oppisite mine was stuck close so every time i shut it off and let it sit over 4 hours the battery would go dead they way i figured it out was that i shut the truck off and checked amp draw and it was over a .5 amp (not good should be like .1 amp max) so i left the amp meter on and started to pull fuses under the hood and the on that stoped the draw was the eec relay fuse so i changed the relay and had no problems after that so i guess it defintly can go both ways glad you fixed it
Old Apr 10, 2004 | 01:46 PM
1956MarkII's Avatar
1956MarkII
We helped a guy fix his Explorer himself, and it cost him $6.35.
I truly love this site!
Old Apr 10, 2004 | 02:06 PM
rburtz's Avatar
rburtz
Actually, two guys! I fixed mine with the advice found here. Major problem solved for $20.00, I replaced both the Fuel Pump and EEC relay to make sure it was fixed right.
Old Apr 14, 2004 | 10:17 PM
Hobatch's Avatar
Hobatch
Hey, found this site through google and then found that you were having the same problems as me. Went and bought 2 relays for $12 and it looks like the problem is solved. Hope you have had the same success.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
