That's just a screen for the end of the fuel sending unit pick up tube. It's definitely not a filter in the sense that it should be changed on a regular basis. Besides, most fuel filters are in a easier accessible location. This one implies that you'll need to pull the fuel sending unit each time to change it. What for? All the contaminants will not actually be contained in that screen like a filter element. Car fuel sending units are usually harder to access because in most cases, you'll need to drop the tank.
Ok, so to change it, one pulls the sending unit (no problem, already done that) and then? The fuel pickup tube is WAY down there. I am no clutz, but my hand is too big and I don't have a needle nose pliers that long!!
Yeah, BB is right. Actually you're all right. I was looking at this last weekend because I thought it was removable, but it is not. So is there a screen on the end of the pu tube? I was considering blowing compressed air back through the pu tube and into the tank to clear any debris that might have accumulated. But I solved my problem before I got that desparate and it runs fine now.
