Modular V10 (6.8l)
spark knocking V10
Old Apr 18, 2004 | 10:25 PM
whomrig's Avatar
whomrig
it seems i typo-d...we only have 91 octane here in the SF area....that is 2.19 AFTER dropping?? sheesh
Old Apr 18, 2004 | 10:37 PM
V10DoubleTow's Avatar
V10DoubleTow
That's at an AM/PM even, cheapest $$ around. Last week when it was $2.299 (I keep forgeting that extra $.009), I spent $82 for a fill. Only spent $75 to fill it today
Old Apr 18, 2004 | 10:48 PM
whomrig's Avatar
whomrig
it seems we should change our name to Ben Dover.....heh heh
Old Apr 21, 2004 | 08:54 PM
Fordtech1's Avatar
Fordtech1
OK, a properly trained dealer technician, with the NGS, and the service card, and the flash cable can turn on the retard function of the PCM. These leave the factory with off as a default, and if someone is experiencing spark knock, this retard feature is switched on.
Old Apr 27, 2004 | 07:33 PM
Dwinn's Avatar
Dwinn
I've been through this ping issue. Had the dealer do the diagnostics ($97.00) and they said everything was fine and that light ping under load was normal. Since I didn't agree, I replace the air cleaner, cleaned the Mass Air Flow (MAF) sensor with a electronics circut cleaner spray (no residue) - carefull these are hair thin wires- and a new fuel filter. This helped some. I then went to the parts store and asked the people what they recommended for a fuel treatment. They recommended Lucas Oil fuel treatment. It's an oil, looks like mineral oil, that goes in the fuel tank. A 6 ounce bottle cost about $3.00. I tried it in a couple of tanks of gas and the ping seems to have gone away for now. I found the Lucas Oil fuel treatment on the web at Interstate Turbo for $15.00 a gal, which makes it far cheaper than the little bottles. Anyway... seems to work for me. I know the weather and so on affects the pinging, but the fuel treatment seems to work. I have also wondered about the anti-knock sensor and have considered replacing it but was tols I have to remove the intake manifold which is a serious job. One note, the dealer said they could manually retard the timing up to 3 degrees to see if that would resolve the pinging. For noe I'll try the Lucas Oil.
brian_j_77
Modular V8 (4.6L, 5.4L)
Jun 21, 2015 08:38 AM
brokeasajoke
Feb 27, 2012 09:58 PM
hossbuilder
1983 - 2012 Ranger & B-Series
20
Oct 12, 2009 06:00 PM
Eric95F150
46
Sep 21, 2007 04:10 PM
mooneyman9
1997 - 2003 F150
Jan 7, 2006 09:20 AM
