starter interchangeability
Old Apr 1, 2004 | 12:05 AM
redneckdieselmechanic's Avatar
Whassup y'all. I am wondering if the starter from a 84 302 w/ AOD would fit in a 84 351 w/ NP 435 4 speed. Appreciate any assistance.
Old Apr 1, 2004 | 06:50 AM
bremen242's Avatar
bremen242
I'm pretty sure the 302 & 351W will swap, but the 300-6 start won't work on a 351w. the bendix is longer on one of them.
go to www.partsamerica.com and look up the different starters to be sure.
Old Apr 1, 2004 | 07:00 AM
82F100SWB's Avatar
82F100SWB
The starters are not engine specific, but, transmission specific.
The 300, 302 and 351W all use the same starter, but, there is a different one for an auto and manual. I know you can use one on the other, but, I forget which. Both will bolt up, but one contacts the flywheel or flex plate, been a LONG while since I had anything other than a stick.
Old Apr 1, 2004 | 07:05 AM
bremen242's Avatar
bremen242
OIC. that is way my starter didn't not fit. now I feel like an a-hole. (my 351w had a C6 and 300-6 had a stick).
Old Apr 1, 2004 | 04:09 PM
found it out y'all
Yeah, its a different starter, I imagine due to a possible different tooth count and/or location of the flywheel on the 4 speed. Appreciate it though
Old Apr 1, 2004 | 08:14 PM
Houndsman61's Avatar
Houndsman61
starter for 302 and windser will swap
Old Apr 1, 2004 | 10:26 PM
Its not that, the trannys are different. One is a AOD, the other is a NP435
dburch84350
Apr 7, 2015 05:05 PM
64deville
Dec 6, 2009 05:16 PM
Ford Radical
Jan 8, 2005 11:59 PM
fordflaresides
Sep 21, 2004 06:56 AM
84w44s
May 21, 2001 02:23 PM
