84 starter relay question please help
Old Mar 22, 2011 | 12:23 PM
dburch84350's Avatar
dburch84350
i have an 84 f350 with a 351w i just got the truck and for some reason someone took the starter relay off and never replaced it now i have a new relay and dont know where the wires go if anyone has a diagram or this it would help so much thanks
Old Mar 22, 2011 | 12:47 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Are you reffering to the starter solenoid mounted on the fender, near the battery?
If so, the positive cable from the battery goes on the large post that faces forward, as well as 1-4 smaller wires with large ring terminals. The cable that runs to the starter goes on the large post facing the rear. There should be 1 more wire with a 90* boot connector, it goes on the small terminal closer to the front of the truck, should be marked with an "S" on the solenoid.
Old Mar 22, 2011 | 03:16 PM
dburch84f350's Avatar
dburch84f350
All of the wires where cut except the starter cable and battery do you know which colors get connected to the big post
Old Mar 22, 2011 | 04:26 PM
guindian28's Avatar
guindian28
here's the wiring diagram from chiltons:
Old Mar 29, 2015 | 07:01 PM
mlogan's Avatar
mlogan
Top bolt hole for starter has chipped off how can I fix it so the starter won't move
Old Mar 29, 2015 | 08:00 PM
Franklin2's Avatar
Franklin2
The bolt broke off? If that's it, take the starter back off and get the broken piece out.
Old Apr 7, 2015 | 04:10 PM
mlogan's Avatar
mlogan
part of the block is broken
Old Apr 7, 2015 | 05:05 PM
GLR's Avatar
GLR
To avoid damage to the ring gear it is best to either replace the starter or the nose piece.
If you're talking about what the bolt threads into, that's the transmission if a C-6.
JordanL79
Jan 17, 2017 12:44 PM
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
Mab1957
Oct 21, 2015 01:25 PM
bobwhyte2002
May 6, 2012 10:30 PM
honeyCANdew
Electrical Systems/Wiring
Jun 14, 2004 05:53 PM
