Sponsored by: Real Truck
aluminum heads
Old Sep 11, 1999 | 05:23 PM
ford?
Guest
Posts: n/a
aluminum heads
What is the major advantage of aluminum heads VS. cast iron heads.
Old Sep 11, 1999 | 06:03 PM
SuperPleased's Avatar
SuperPleased
aluminum heads
1. Improved heat management. Aluminum transfers heat much more readily than cast iron, and therefor gets the heat from the cylinders' compression chambers into the water jacket more efficiently.
2. Weight reduction. Those cast iron cylinder heads are very *heavy*, when compared to aluminum heads.
Old Sep 13, 1999 | 12:14 AM
V10 MAN's Avatar
V10 MAN
aluminum heads
Like SuperPleased said, they run cooler. This allows for higher compression ratio which makes more power.
Old Sep 13, 1999 | 06:28 AM
Deen Hylton
Guest
Posts: n/a
aluminum heads
From what I've read you can run about a half point more compression on aluminum without detonation. Also aluminum is much more repairable than cast (cast has a tendency to crack around the weld) and is more workable when porting and polishing.
Old Sep 14, 1999 | 07:32 AM
Devin Sarver
Guest
Posts: n/a
aluminum heads
oldmerc
Mar 1, 2012 10:33 AM
MER
21
Feb 2, 2008 04:02 PM
wayne123
Feb 20, 2006 11:31 PM
SOBCspeed
Sep 4, 2002 07:08 AM
chriseaton
Aug 22, 2002 07:48 AM
