headers
Old Mar 30, 2004 | 08:12 PM
Josh79's Avatar
Josh79
headers
I have built the 351m in my 79 f-150. It is now a 410 with a 4 barrel carb, intake among other things such as a 268H comp cam. It is dualed out w/ some fairly long old glasspacks, about 24" or so I would guess, which I am planning on replacing with 18" glasspacks or the Dynomax Bullet race muffler. I want to put headers on it. I have looked @ the dynomax standard series headers. They have 2 listed for my pickup. One is 1 5/8" and the other is 1 3/4". What are the pros & cons of each? Does the size difference matter? Also how would the purple hornie header mufflers sound compared to a 18" glasspack? I assume it would be quieter is this right? Any help or opinions would be appreciated.
Old Mar 30, 2004 | 11:14 PM
beeboy's Avatar
beeboy
I just tried putting the dynomax ceramics on my 79 F150 4x4 and ran into problems. The passenger side header rubbed the frame, and the drivers side sits only 1/8" from my front driveshaft. I have a set of hedmans on their way to try next.
Old Mar 31, 2004 | 07:21 PM
Josh79's Avatar
Josh79
thats not good. anyone running a brand that fits properly?
Old Mar 31, 2004 | 11:36 PM
FERacing66's Avatar
FERacing66
ive heared nothing but good so far about hedmans.
Old Mar 31, 2004 | 11:47 PM
beeboy's Avatar
beeboy
they'll be here thursday..I hope they fit nicely! I did talk to Hedmans support about the coating on the Elite series of headers. You can also get their regular line in a ceramic coat, but the price is higher than the Elites with ceramic coat. The coating on the elites is thicker, but dull gray in color. The regular ones when coated have a polished coating, shiny but thinner.
Old Apr 1, 2004 | 07:57 AM
freak98's Avatar
freak98
I put Hookers on mine,there close but they work.
Old Apr 1, 2004 | 04:21 PM
824x4ride's Avatar
824x4ride
i have a set of hedmans on my 78 f-150 4x4 and they fit great. no clearance problems anywere....so i would recommend the hedmans for ya
Old Apr 1, 2004 | 07:29 PM
beeboy's Avatar
beeboy
They got here today. First impressions, they are impressive! They weigh alot more than the dynomax's, due to their thicker tubes and heavier flanges. The instructions are better than what dynomax provided. The hedmans also come with the materials to hook up the air cleaner stove pipe, and to connect to the Y pipe if you have one. Impressive. I am missing the collector gaskets, have to call Hedman in the morning about that. They have the CARB sticker for emissions. Holding them next to the Dynomax's, they look like they should fit better. I'll get them on soon! FYI these are model 89218, Hedman Elites for the 79F150 351m/400 4x4.
Old Apr 1, 2004 | 08:06 PM
Josh79's Avatar
Josh79
well thanks for the info. tell me how they fit after you get them put on. just out of curiousity do you have ac on your truck beeboy?
Old Apr 1, 2004 | 08:15 PM
beeboy's Avatar
beeboy
I wish I had AC...that would be the cats meow for my truck..might have to find one of those aftermarker units.
Old Apr 1, 2004 | 08:20 PM
Josh79's Avatar
Josh79
ya ac is nice even though i need to do some work to mine. headers should fit just be a little tight but ought to work
Old Apr 3, 2004 | 11:17 AM
Josh79's Avatar
Josh79
what did you get with the headers beeboy? do they come with bolts, reducers etc or do you have to get it all seperate?
Old Apr 4, 2004 | 12:21 AM
beeboy's Avatar
beeboy
Got them on it today. I called Hedman, they don't use collector gaskets anymore as they now form the collector with a ball end. Very cool! They do come with reducers, all the bolts, the stove pipe connection, and adapters for a Y pipe. Hedman loses a point for throwing in cheap paper header gaskets, I went and bought some fel-pro metal core ones to use instead. The Hedmans were a bit trickier to install than the dynomax's, I had to lift the engine, and drop the front driveshaft to get the drivers side one in. But they fit so much better than the Dynomax's! Thicker flanges do not bend when tightening them down. Clearance around the frame is much better, and the driver side one tucks close to the block and comes out on the passenger side of the front driveshaft, which gives it alot of clearance there and will make it easier to hook the exhaust to(both pipes running to the passenger side). I'll get some pics loaded into my gallery of these. I must say, for the $35 more the Hedmans cost, they are easily worth every penny.
Old Apr 4, 2004 | 09:03 PM
Josh79's Avatar
Josh79
is lifting the engine a must do? or does it just make installation easier?
Old Apr 4, 2004 | 09:44 PM
beeboy's Avatar
beeboy
It shouldn't have been necessary, but I could not get the steering shaft off. Since I had the lift at the ready, it was an easy way out for me. Their instructions do not indicate that it is necessary to do.
kyle1979ford
26
Aug 14, 2013 10:29 PM
Theisen20
1997 - 2003 F150
Sep 20, 2011 02:59 AM
1966Tbird
Apr 7, 2009 10:01 PM
Josh79
Exhaust Systems
May 1, 2004 12:16 AM
tak
Exhaust Systems
Aug 9, 2002 06:59 AM
