Buff Touch up paint ?????
Old Mar 30, 2004 | 01:35 PM
tripleplaytours's Avatar
tripleplaytours
I touched up about 100 rock chips and scratches (once i got going i couldn't stop) on my "Red Ranger" and from 15 feet it looks new (1996 supercab) but from 5 feet you can eally see the bumps and ridges from the touch up - My question is how can I smooth these "bumps" out without getting myself into alot of trouble with the factory paint/clearcoat or can I wet sand these and clear over small spots from a spray can from napa
Thanks
Old Mar 30, 2004 | 05:40 PM
marc9000's Avatar
marc9000
Sounds like it might be worth trying on one small, inconspicuous spot, to see how it works. I'm not familiar with that napa product (rattle can clear?) but it's almost certain to leave a dry haze around anywhere it's sprayed, and if it doesn't polish well, I'd guess you'd be worse off than you are now. Try cutting about 1" off the end of a paint stick, and use it as a small sanding block. Wrap 400 grit sandpaper around it and see how that levels the bumps. Use rubbing compound, or 1200 or 1500 grit sandpaper to clean the whole area that you clear. Polish the clear according to the can directions.
You'll probably have better success if the color is solid and not metallic.
Just my .02 - good luck!!
Old Apr 3, 2004 | 04:28 PM
GLOCK17's Avatar
GLOCK17
Dont Take 400 To The Hood Or You Will Have A Repaint.1000 On A Sanding Block Over The Touch Ups Rember Lots Of Water Use A Squee-gee To See When Your All Most There Then Go To 1500 And Buff Will Never Look Mint But Will Look Very Good Tust Take Your Time
Old Apr 3, 2004 | 06:32 PM
tripleplaytours
Thanks guys I'll give it a try
gtmustang00
Paint & Bodywork
Feb 27, 2008 11:48 PM
jnye6625
2004 - 2008 F150
Feb 18, 2008 12:37 PM
freirefishing
General Automotive Discussion
Feb 14, 2007 12:41 PM
Wanted
1983 - 2012 Ranger & B-Series
Mar 6, 2005 07:57 PM
