1978 - 1996 Big Bronco
convert automatic to manual hubs
Old Mar 30, 2004 | 11:01 AM
Tidybowlman0's Avatar
Tidybowlman0
I am want to put manual hubs on my 87 Bronco. I went to NAPA thay said that the manual hubs will not work on '87 flang mount'.
How do I tell if mine are flang mount or not?
Old Mar 30, 2004 | 11:10 AM
ANdrewdrice's Avatar
ANdrewdrice
you should do a search of the forum, this is the most talked about topic in here. I dont know hat you need but im sure it will tell you in the search
Old Mar 30, 2004 | 12:58 PM
DW2455's Avatar
DW2455
i ahve a 87" with flange mount hubs, if you remove your front wheel and you have flang mount hubs, then the whole hub asy. will come right off in your hand, it's held on by the wheel it self, but mine are manual, so you may be able to check some bone yards for some manual ones, im not shure if they make the after markey flange ones, mine where on it when i bought it. another option would be to change out the whole spindle asy, but i have benn told by two reputable 4X4 shops that it would be just as easy to swap out the whole axle unit as to change just the spindles, kinda sounds like a pain in the A.. to me, Good luck, let me know what you find out. DW
Old Mar 30, 2004 | 01:04 PM
BillyBob69's Avatar
BillyBob69
Which ones look like yours?
http://www.imagestation.com/picture/...9.jpg.orig.jpg
If its the little one on the right, then you have the flange mount. You can get both from WARN. Check with NAPA again. They should be able to get you both styles.
Old Mar 30, 2004 | 01:09 PM
DW2455's Avatar
DW2455
BillyBob69 ; thanks billybob, i'll keep that in mind i hadnt looked for them aftermarket cuz mine are manual and they still work for now so why replace them right? Thanx. DW
Old Mar 30, 2004 | 04:56 PM
Tidybowlman0
I will be doing the conversion in the AM. I'll just pick up both sets of hubs and return the ones that I don't use. I'll let you know how it goes. Thanks....
Old Mar 30, 2004 | 05:39 PM
BillyBob69's Avatar
BillyBob69
This may help a bit. It takes you as far as the ball joints but just stop at the hubs. That is if its similar to your set up.
http://www.off-road.com/ford/bigbron...balljoint.html
Old Mar 30, 2004 | 06:20 PM
Tidybowlman0
thanks billybob69.......that will help alot
Old Mar 30, 2004 | 07:52 PM
DW2455's Avatar
DW2455
Tidybowlman0; look at the end of you hubs if it has little screws around the end of the hub then there regular hubs, if there are no screws around the end then there flange mount. DW
Old Mar 30, 2004 | 08:23 PM
Tidybowlman0
Thanks DW2455 now i only have to buy the one set and not have to go back to return the other. I HATE STORES of all kinds
Old Apr 1, 2004 | 02:44 PM
Tidybowlman0
Well I started the conversion but I cant find the retaining ring. I think that it should be on the end of the axle shaft. for some reason I can't see it (must be getting old).
If I use a gear puller to pull out the body of the hub do you think I'll screw up the axle shaft?
Old Apr 1, 2004 | 02:57 PM
DW2455's Avatar
DW2455
I have never done this conversion my self but i'll tell what a read in the link posted above, once you get the cap off there should be a snap ring around the end of the axle shaft that you need to remove with snap ring pliers, then there should be a C-clip ring in a grove on the inside of the hub housing and it will be kinda hard to see take a rag and wipe it good to remove the grease so you can see it, when you have these two rings removed you should be able to work the asymbly out.
look at this link that billybod posted for you!
https://www.ford-trucks.com/lc/lc.ph...balljoint.html
GOOD LUCK DW
Old Apr 1, 2004 | 02:59 PM
DW2455's Avatar
DW2455
by the way which ones did you end up having? DW
Old Apr 1, 2004 | 03:18 PM
Tidybowlman0
I have the bigger 5 screw automatic hubs not the flang mounts.
I got the C-clip ring out It's the snap ring that I can't find.
Maybe I should try the old military way A big screwdriver and a BF hammer
Old Apr 1, 2004 | 03:42 PM
bronco5.8's Avatar
bronco5.8
That big ring is kind of tricky, you'll need two small screw driver's and a light to find the gap on that ring. Once you find that gap use the small screwdriver's and pry that ring out. You don't force that ring out but it's tricky to get out.
Warr
