1978 - 1996 Big Bronco
convert automatic to manual hubs
Old Apr 1, 2004 | 03:45 PM
Tidybowlman0's Avatar
Tidybowlman0
The big ring I had no problem with its the small one that I cant get
Old Apr 1, 2004 | 03:50 PM
bronco5.8's Avatar
bronco5.8
Sorry about that, if it's the snap ring on the axle your talking about you should be able to see it and pop it off using the two screwdriver's.
Warr
Old Apr 1, 2004 | 04:07 PM
Tidybowlman0
It is the snap ring on the axle that i'm having problems with. I can't see it besause of the grease I guess.
Old Apr 1, 2004 | 04:16 PM
bronco5.8's Avatar
bronco5.8
This clip is further inside the hub, just follow the splines on the axle and you'll see a c-clip. Once you pop the clip off there should be 3 washers, slide those out and now you can slide the cam assembly out. Once that is out you'll see a retaining key that holds the wheel retainer nut. Get the key out with needlenose pliers and then you'll need a 2 1/2 inch socket to take the nut out.
Just out of curiosity, did you get the conversion kit? This kit consists of 4 nuts and 2 lock rings. Let me know. Sorry for the slow response, computer acting up.
Warr
Old Apr 1, 2004 | 04:34 PM
Tidybowlman0
Yes I did get the conversion kit. going out to try to find the C-clip gain. I'll let you know how it goes.
Old Apr 1, 2004 | 07:10 PM
Tidybowlman0
Sorry it took so long to get back.....I ran in to another proplem....my neighbor is reading the instructions and it seems that the verson that he is holding calls for a beer every other step.......Time to loose the neighbor I think (still like the instructions) Try again in the AM.
Old Apr 1, 2004 | 08:18 PM
bigric's Avatar
bigric
See if this helps:
http://www.broncodata.com/tech/tshubconv.htm
Oh, and have another beer
Old Apr 2, 2004 | 08:37 AM
bronco5.8's Avatar
bronco5.8
There you go!, pictures at this site from bigric explains better than words. Good job bigric.
Tidybowl, if that locknut pictured is the same one you have then you don't need that conversion kit.
Warr
Old Apr 2, 2004 | 03:16 PM
Tidybowlman0
Well I got the hubs replaced (thanks for the link bigric) it only took me a day and a half on the passenger side and 20 min on the driver side. I also returned the conversion kit (not needed). Hummm what to spend that $60 on......
Old Apr 2, 2004 | 03:20 PM
DW2455's Avatar
DW2455
Well now you can buy us all a beer for all the internet mechanicing we been doing! DW
Spaznaut
Dec 12, 2007 09:12 AM
88 f150
Dec 23, 2006 03:31 PM
MTMike
Dec 11, 2004 05:10 PM
