Sponsored by: Real Truck
Front suspension making slaping noise
Old Sep 25, 1999 | 04:53 PM
gener's Avatar
gener
99 F-350 4x4 crew cab LWB DRW
front suspension making slaping, banking or knocking noise. Has any one had this noise, sounds
like a warped rotor or a tire out of round but when you push down on front end you can fell the
front spring banging
Old Nov 3, 1999 | 04:19 AM
Mark's Avatar
Mark
My 99' F350,SD, super cab, CxC 4x4 clunks and bangs under cab and in front end , have'nt found it yet, going to the dealer today for other stuff and that, let me know if you find out what it is, I'll post a new ad with my results, ..Mark
Old Nov 9, 1999 | 04:53 AM
Mark's Avatar
Mark
Got my truck back 11/5/99, was at dealer for, Driver side power window problem, rear spring sqeak,tires out of balance,clunks and bangs under cab,when truck is loaded, it shudder's when you take off up to about 15 MPH,TSB on it has to do with rear end driveshaft angle and carrier bearing ( will go back for that).This truck weighs 5 ton without a loud in the dump body, only gets 11 to 13 MPG, almost 9,000 miles and it has the PSD.
Anyway the tech seemed to find the clunks it was the swaybar( driverside drag link, he replaced it, and spent time on cab mounts also),
The rest of the probs they seem to have fixed them also, The dealer is Columbia Ford In CT.
Old Nov 9, 1999 | 05:55 AM
Mark's Avatar
Mark
resq302
Aug 21, 2018 10:29 AM
yohon
Sep 3, 2016 08:08 AM
kconrad
Aug 1, 2015 11:35 AM
Tyler Burdett
Dec 7, 2009 10:07 AM
milmo1
Mar 8, 2005 04:51 PM
