GEM replacement then flash upgrade?
Old Dec 16, 2005 | 10:09 PM
TX76F250's Avatar
TX76F250
Problem: Rear wiper no workie. No bad fuses. No bad relays. No bad motor.
Problem: Washer fluid low indicator on all time.
Troubleshot down to the GEM that all these functions are controlled through. Then read on my service manaul CD that if I was able to get the GEM out and replaced that I would need some special gizmo and cable to "flash upgrade" it.
That would seem to limit this repair/replacement to the dealer and that sucks!!
The GEM is located on the "back" of the interior fuse panel and is a *bear* to get to and to get out.
Any suggestions for me would be greatly appreciated.
Old Dec 17, 2005 | 12:53 AM
Racerguy's Avatar
Racerguy
You're supposed to "move" the programming from the old GEM to the new one when you replace it but I've done lots without doing that.
I think you'll find instructions for replacing the GEM in the F-150 forum.
Basically you remove the dash trim under the steering column, remove the 2 big connectors off the back of the fuse box, unbolt the fuse box/GEM, then unplug the connectors and remove the fuse box/GEM.
WestCoastTodd
Aug 15, 2018 06:45 PM
gkotlin
May 27, 2017 08:50 PM
CLE-PRE
Feb 9, 2017 02:30 AM
sabbyone
New Member Introductions
Feb 12, 2010 09:55 PM
clay30
1997 - 2003 F150
Jan 14, 2003 09:17 AM
