chip?
Old Mar 28, 2004 | 02:53 PM
dlw's Avatar
dlw
chip?
I have just purchesed a 1999 F250 power PSD I am new to this engine. How do I tell if someone has put a chip into it?
Old Mar 29, 2004 | 09:12 AM
JMorton's Avatar
JMorton
On your truck you can look up under the dash next to the e-brake pedal and see the PCM. If there is a chip installed, the plastic cover will be removed and you'll be able to see the chip piggy-backed onto the back of the PCM.
Old Apr 5, 2004 | 07:38 PM
greygoose's Avatar
greygoose
How can I tell on my 96 F-250? Is the PCM in the same place?
Old Apr 5, 2004 | 08:26 PM
fourstroke's Avatar
fourstroke
You will have to remove the E-brake pedal assy. (three bolts if I remember right), and you will see the pcm behind it. Stock has a black plastic cap in the center of it, if it has a chip it will usually have the mfr. name on it, however most mfr.'s suggest using duct tape over it to secure it. Of course this info only applies to chips installed at the pcm.
