Explorer front grill removal
Old Mar 28, 2004 | 02:51 PM
9explorer8's Avatar
9explorer8
Sometimes the simplest things are the most baffling. I want to take the front plastic grill off of my 98 Ford Explorer to repaint it. The procedure is not in any manual I have. I can remove the four screws, located just under the hood, that secure the top of the grill. The top of the grill then seems loose, but the bottom and the trim around the headlights, which is also connected to the grill, will not turn loose and I can find no screws or fasteners. My guess is that there are press-in fasteners somewhere behind the bottom parts that can be pulled out with the grill, but I don't want to break the grill or trim trying out that theory. Any help would be appreciated. Thanks much in advance.
JD
Old Mar 28, 2004 | 04:36 PM
ltfox's Avatar
ltfox
I cannot remember exactly so dont take this a the gosple but I remember a couple of screws that were behindeither the head light or the turn signal lamp and then like you said press in fasteners at the bottom. Good luck
Old Mar 28, 2004 | 06:08 PM
9explorer8's Avatar
9explorer8
ltfox, thanks a heap. You were exactly right. There was a screw that had be removed hiding behind each headlight assembly in the marker light area. Then there were 4 clips at the bottom. Good memory!!!!
Thanks once again.
JD
flamebuster
2011 - 2019 Explorer
Mar 14, 2017 11:55 AM
blackexplorer16
Sep 7, 2016 11:14 AM
ogarcia434
Aug 21, 2016 01:37 PM
HIO Silver
Feb 23, 2016 07:59 PM
nutinbutford
Oct 25, 2005 06:41 PM
