Sponsored by: Auxito
crew cab w/limited slip problems
Old Mar 28, 2004 | 12:52 PM
bobby k's Avatar
bobby k
I have a 1997 f250(light duty) w/9.75 limited slip rear differential. I just had it serviced and filled with 75/140 synthetic as noted on axle tag. It growels and chatters like crasy...sooo bad I don't want to drive it. Any suggestions will be greatly appreciated.
Bobby K
Old Mar 28, 2004 | 09:23 PM
jvangel's Avatar
jvangel
Did they add friction modifier? Was it serviced through Ford? If not, then go ahead and buy some "FORD" friction modifier and throw it in your differential. It will take some time for that crap to have an effect, but it just might help. My 97 was doing it like crazy. I changed out my differential fluid, added modifier (not ford) and no change at all. Went to Ford, bought theirs and dumped it in and it helped some. It still chatters but not as much.
Old Mar 30, 2004 | 03:35 PM
Heritage___150's Avatar
Heritage___150
just got my 03 f150 back from dealership. they had to replace the limited slip clutch. when i would take off with wheels slightly turned it chatter and stutter for a bit.
now everything is fine
Old Mar 30, 2004 | 09:12 PM
superrangerman2002's Avatar
superrangerman2002
Some thimes you have to watch the aftermarket friction modifer as it come in all kind of different qtys....most common ones I've seen are 4 oz and 8 oz bottles.
Old Apr 1, 2004 | 09:33 AM
drighten's Avatar
drighten
You didn't say if the diff growled and chattered BEFORE you serviced it. If it did, then you may have mechanical problems. If it didn't, then a friction modifier (Fords if probably best) in the recommended quantity should fix it.
Thom
Old Apr 1, 2004 | 09:50 AM
jvangel's Avatar
jvangel
My truck was fine and then it gradually started the chatter while in a turn from a stop.
Old Apr 1, 2004 | 11:15 AM
MrBSS's Avatar
MrBSS
Did you have it changed because it was chattering, or did it start to chatter after it was changed?
If the latter, I would certainly suspect it needs friction modifier. But if you add too much, it will lose some of its limited slip ability.
