service bulleting question
Old Mar 28, 2004 | 04:42 AM
dcarhart's Avatar
dcarhart
I see there's a service bulletin on the 2001 ranger #17255.
which has the summary "HARD START/LONG CRANK WHEN COLD OR STUMBLES/SURGES DURING DRIVE-AWAY. POSSIBLE DIAGNOSTIC TROUBLE CODES P0171, AND P0174 OR P0172 AND P0175. *TT "
mine has this stumble, always has. anyone know what the dealership would do / charge for if I brought this in?
TIA, Dave
Old Mar 28, 2004 | 11:12 AM
iverger's Avatar
iverger
I believe these are all lean/rich codes. Ford would likely start by replacing all of your O2 sensors. Always changed them myself, not sure what they would charge. If your not getting the codes you should also consider plugs and wires.
Old Mar 28, 2004 | 12:12 PM
Rockledge's Avatar
Rockledge
I'm not sure about that TSB that you mention, but there is another TSB that was issued a few years earlier that discusses the effect that a dirty MAF sensor can have on a Ford engine. Some of the symptons of this problem can also include "Hesitation/Surge on Acceleration" and possible trouble codes P0171, P0172, P0174, and P0175.
Take a look:
https://www.ford-trucks.com/forums/s...hreadid=128532
Old Jun 16, 2004 | 04:40 PM
JF808's Avatar
JF808
I also see that there's a service bulletin for my 1999 Explorer 4.0L 4X4- TSB# 03-9-8, issue date: May 03 which has the summary "Emissions-MIL ON/EVAP System DTC's Set". My check engine light has been on some time now. so yesterday I ran my new code scanner and received PO455"
I am also wondering what the dealership would do or be required to do, based on the TSB and my problem.
Old Jun 16, 2004 | 05:05 PM
87 XLT's Avatar
87 XLT
I've solved a couple of problems on my Ford's by simply stopping at a Ford dealer & reading a TSB.
Old Jun 16, 2004 | 07:27 PM
Ken00's Avatar
Ken00
A TSB is not a recall, if your out of warranty you will have to pay for the repair.
Old Jun 18, 2004 | 05:26 PM
JF808's Avatar
JF808
Tsb
Thanks you answered my question on the TSB.
ClarkWGriswold
Aug 7, 2015 08:11 PM
99eddiebexpedition
Jan 31, 2015 11:34 AM
mixerdrvr
Jan 9, 2011 03:37 PM
tiredlr
Nov 28, 2010 08:36 AM
pommesdeux
1997 - 2003 F150
Sep 21, 2010 04:36 PM
