Sponsored by: Real Truck
Engine block heater
Old Jan 4, 2000 | 02:56 PM
Chip's Avatar
Chip
Engine block heater
All right, I am one of the few who ordered one with on a gas V10, but I can't find the friggin thing! I have looked all over the engine compartment, behind the bumper, everywhere and I can't figure out where to plug this bad boy in.
Is there some kind of cable conversion kit that the dealer is\was supposed to give me?
The manual says driver side, my dealers service guy said passenger side. HELP!
Even though it was less than $40 its on the window sticker, it should be there.
Any help finding this is greatly appreciated!
Old Jan 4, 2000 | 03:30 PM
russ's Avatar
russ
Engine block heater
>this bad boy in. Is there
>give me? The manual says driver
>passenger side. HELP! Even though it
>there. Any help finding this is
Old Jan 4, 2000 | 03:34 PM
russ's Avatar
russ
Engine block heater
My 99 v10 has it also,look behind the lower grill area slightly on drivers side.It is hard to spot because of a black rubber cap over it.
Old Jan 8, 2000 | 06:46 AM
PJC's Avatar
PJC
Engine block heater
I ALSO HAVE A V10,THE LOCATION OF THE PLUG END MAY BE SLIGHTLY DIFFERENT ON THE SUPER DUTY LARIAT DUE TO THE TEMPERATURE SENSOR WIRING SHARING THE SAME PATH, BUT MY 2000 PLUG END IS JUST TO THE RIGHT OF THE LICENSE PLATE MOUNT AND TUCKED UP A BIT.
Old Jan 13, 2000 | 10:52 PM
snomoman's Avatar
snomoman
Engine block heater
I opened the cap on the plug, and found it full of water! Many others have had the same problem. Kind of makes sense, due to it's location. Do yourself a favor, and pack the whole thing with vaseline or grease. Otherwise, if you ever needed it, it would be froze solid in an ice cube.
Old Jan 23, 2000 | 08:25 AM
spaceace's Avatar
spaceace
Engine block heater
If your still having a problem locating it. Look on the frame rail behind the driver's side tire. It's the only harness running to the front bumper.
I installed it myself aftermarket, an exact factory harness and plug with all mounting tabs.
Ever wonder what all the extra holes were in the frame. Believe it or not, each one has a purpose.
www.angelfire.com/pa3/spaceace
Old Jan 24, 2000 | 06:52 AM
cowboy's Avatar
cowboy
Engine block heater
I have a 99 super duty and my plug is to the right of the lic. plate just inside the bottom grill opening and it works great
Old Jan 24, 2000 | 07:16 AM
_cwadlow's Avatar
_cwadlow
Engine block heater
Went to the dealer Saturday, after two mechanics, service manager, and finally the shop manual, discovered that the factory never installed it.
The final deciding factor was that the heating element itself was never installed. It goes on the drivers side of the block were the number 2 freeze plug is.
I decided it wasn't worth the hassle of having one installed, let alone the potential for problems afterwards.(Removing the freeze plug, etc.)
Now I just need to see what the dealer/Ford plans on doing since I did pay for it, with tax and interest.
Thanks to all for your help in trying to track this down, I will let you know what happens next.
Chip
Old Jan 24, 2000 | 04:35 PM
spaceace's Avatar
spaceace
Engine block heater
IT IS ALL ORIGINAL IF YOU GET IT FROM THE DEALER> It's a class product and I did it myself. Takes 5 minutes once it is drained. Costs $50 if you have to buy it off the shelf.
You paid about $27, They will have at least that into it.
Worth the money IMHO
spaceace
Old Jan 27, 2000 | 07:35 AM
none's Avatar
none
Engine block heater
Silentst2000
Nov 4, 2019 09:51 PM
83f2506.9L
Sep 4, 2012 10:07 PM
pilot4x41
Jul 31, 2010 01:35 AM
okwaho1650
Oct 27, 2008 06:26 PM
rxtr
1983 - 2012 Ranger & B-Series
Jan 17, 2004 07:36 PM
