Can't find knock sensor on the a 94 4.9
I can't find the knock sensor on this engine. Either that or NAPA sold me the wrong sensor because I can't find anything with the same connector on the block of the engine. Is the sensor on the header side or side case gasket side? Could someone help me out here please?
Oh, crap! I stand corrected. My engine is still on the stand, mostly disassembled, but still has all the sensors in place. Thought the one on the other side rear was the knock sensor. (too many GM's i guess. Theirs is on pass rear and has one wire) So what is the one I was thinking about? Temp sender for the guage maybe?
Yes the one you mentioned it's the engine block temperature sender for the temp gauge I have remplace it my self. And the one by the coil it's a capacitor, ( if you are taking about the one installed on a bracket next to the coil) I'm working on installing a megasquirt2 3.57 and I need to find that sensor
see if that helps, couldn't find anything searching the parts houses but I haven't tried rockauto.com Part in this picture is what you were looking for?
danjohnson67
03-03-2016 04:29 PM
bartlettf150
05-22-2015 09:10 AM
DA080682
1997-2006 Expedition & Navigator
02-27-2007 07:15 PM
