starter relay idiot
Old Mar 27, 2004 | 04:58 PM
f1501988's Avatar
f1501988
starter relay idiot
undefined
I have a F 150 1988 302. 165,000 miles. I replaced the starter relay and along with a battery and alternator several months ago. The starter melted my battery cables and relay so I replaced starter. This was the initial problem. I have had an intermittent starting problem ever since. My truck will start fine for a week or two and than all of a sudden I will have to by pass the ignition switch at the relay to start the truck. This begins with a kind of buzz noise. I go to the relay and play with the green wire which allows the radio to come back on and the engine compartment light to come on. That tells me I have juice and can now junp the truck at the relay. Once that starts to happen it will not start normally again. I am on my third relay and am thinking I have some how got the wrong wires on the wrong side of the relay.
I have the connections like this. On one side of the relay I have a large black wire coming from the starter. There are not any other wires attached to that side. On the other side of the relay I have I have a single green wire that if I wiggle or turn makes the hood light come on and I can jump it. I have a double Black into a fusible link comes out yellow on the other side of the fusible link. The posotive battery cable is also on that side of relay.
Any wisdom would be appreciated.
Mike in Ohio
Nov 27, 2012 01:31 PM
tndrhrtmedic
15
Sep 10, 2011 06:14 PM
aricanderson
Nov 30, 2009 05:53 PM
rong63
17
Feb 8, 2006 11:45 AM
f1501988
Electrical Systems/Wiring
Aug 8, 2004 10:17 AM
