relay idiot
Old Mar 27, 2004 | 05:29 PM
f1501988's Avatar
f1501988
relay idiot
I have a 1988 F150 165,000 miles. Several months ago my starter fried my relay and melted my battery cables. So I replaced my batter relay an alternator. About every couple of weeks I start to have an n intermittent starting problem and have to bypass ignition switch at the relay to start the truck. My suspicion is that I have placed the wrong wires on the wrong side of the relay. I have the relay wired in this way. On one side of the relay I have a large diameter cable coming from the starter. On the other side of the relay I have the positive battery cable and a green single wire. The green wire is connected to a fusible link. This green wire comes from the alternator. I than have double black wires and on the other side of the fusible link it becomes a yellow wire. When I try to start the truck I get a buzzing type of noise. I have to wiggle the single green wire to get the engine compartment light to come on and the radio if it was on so that I can jump the relay. Any wisdom would be appreciated.
