1978 - 1996 Big Bronco
Popping Noise
Old Mar 27, 2004 | 10:33 AM
Herc Eng's Avatar
Herc Eng
Angry Popping Noise
I need help, my son's 1990 Bronco intermittently will make a loud "pop" coming from the right front wheel area when the brakes are first applied. The steering wheel will shimmy until you come to a complete stop. You can then usually drive it all day with no more problem. I have jacked the front end up and there is no play in anything, we replaced the brakes several months ago any they are still good. I am thinking of replacing the wheel bearings as a starting point although they appear OK. He does have the automatic hubs, not the manual ones. Anyone have any ideas?
Thanks
Old Mar 27, 2004 | 11:13 AM
DW2455's Avatar
DW2455
some ideas, lugs tite, wheel bearing, caliper mounts, ball joints,. if your getting wheel shimy and you dont find any play anywhere, you may want to have the front rotors turned for high spots, one could have a slight warp in it, DW ?????
Old Mar 27, 2004 | 11:31 AM
WhëëlMå1's Avatar
WhëëlMå1
Along with what DW2455 mentioned, you might want to check youre radius arm bushings. If they are worn out, the forces of braking could make the whole assembly move, and result in the clunk from that side. This might not apply, since you said you checked everything over in the braking system, but my father had a similar clunk on his bronco. As it turns out. the bracket holding the calipers had actually loosened and caused one of the bolts to "dissapear". When he would get on the brakes, he would hear a clunk. It turns out the whole assembly moved during braking.
Rich
Old Mar 27, 2004 | 11:44 AM
DW2455's Avatar
DW2455
yup forgot the radius arms DW
Old Mar 27, 2004 | 11:59 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
also check the caliper retainer. they have a bad tendancy to move as wheelma1 said. i'm not sure if you have the compression retainer or a real bolt, but I know for a fact that the compression retain can back itself out and let your caliper move around
Old Mar 27, 2004 | 10:10 PM
prick1's Avatar
prick1
I'm on my 5th Ford 4x4 the radius arm bushings can look good
but make pops that are deciving to there wearabouts. Check the bushings close.
Old Apr 2, 2004 | 12:16 AM
Superman_ManOfSteel's Avatar
Superman_ManOfSteel
im with the other guys, have the rotors turned. Just to eliminate the chance of warped rotors. Also try driving in reverse then applying the breaks a few times. This may adjust your breaks some(if thats the problem). hope this helps.
trim man
Feb 21, 2009 09:22 AM
khelms_98
Oct 28, 2005 07:41 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
Apr 29, 2005 11:08 AM
amsnss
Dec 25, 2004 08:54 AM
peck87
Bronco II
Mar 21, 2004 09:55 PM
