Q-jet w/ adpter "?"
Old Mar 26, 2004 | 08:21 PM
jrongi1's Avatar
jrongi1
Question Q-jet w/ adpter "?"
Are the Q-jets still that great a carb if you have to use an adpter for a square bore intake?
BTW it will be for a 79 Bronco w/400 (mild off-roading and street/interstate use).
Old Mar 27, 2004 | 02:09 AM
200000+F150's Avatar
200000+F150
I'm running one with an adapter with zero problems(except setting up the kickdown). You might consider swapping to a cable for this. An aftermarket intake with an open plenum would probably be better than the factory 4-hole, but mine is working great.
Old Mar 27, 2004 | 07:08 AM
Ford_Six's Avatar
Ford_Six
There are four hole adaptors available. IIRC, they are made by Mr. Gasket.
Old Mar 27, 2004 | 10:41 AM
jrongi1's Avatar
jrongi1
This will be going on a preformer intake. for ether a 400 or a 302 depending on how well it works for the 400. (ebay carb)
Old Mar 28, 2004 | 12:43 AM
BroncoRoadKill's Avatar
BroncoRoadKill
You guys should be ashamed. Putting GM parts on your Fords. Go buy a holley truck avenger carb for you bronco.
Or not, thats why I love america.
Old Mar 28, 2004 | 03:12 AM
200000+F150
Haven't had any experience with the truck avenger carbs, but I've heard good things about them. On the other hand, I heard good things about the old standard Holley carbs, and you couldn't run fast enough to give me one of those pieces of crap. The aluminum would be better used making beer cans.
Old Mar 28, 2004 | 03:34 PM
76supercab2's Avatar
76supercab2
Why? FORD did it.
Old Mar 28, 2004 | 09:34 PM
BroncoRoadKill
I use eldelcrap carbs for boat anchores, and trout line weights.
supercabfreak
39
Feb 27, 2017 08:50 PM
fordboy300
31
Apr 16, 2011 09:49 PM
kermmydog
Jan 18, 2010 12:16 PM
Blue Bomber
Jan 7, 2009 12:16 PM
