Sponsored by: Real Truck
bolt pattern
Old Feb 17, 2000 | 09:19 PM
4rdgasm's Avatar
4rdgasm
bolt pattern
Is the bolt pattern off of the old(90's) 3/4 tons, the same as the new SD? I don't mean the light duty 3/4 tons either.
Old Feb 23, 2000 | 03:02 AM
V10man's Avatar
V10man
bolt pattern
the old style was a 8 lug, 6.5" diameter pattern. The new style, is 8 lug, 170mm diameter pattern. I think the 170mm is a tad bigger. Also, the center hole is different. Ford uses the hole to center the wheel on the hub where the old sytle used cone shaped lugnuts.
Old Feb 24, 2000 | 09:12 PM
Steve R's Avatar
Steve R
bolt pattern
Old Mar 1, 2000 | 09:41 PM
4rdgasm's Avatar
4rdgasm
bolt pattern
thank you. The info will help me for what I need.
RMCOTNER
1947 and Older Ford Trucks
Feb 21, 2018 08:52 AM
e_coots
Jan 8, 2017 12:09 PM
Highboy Honk
Sep 2, 2014 08:45 PM
daddio360
Jul 28, 2008 03:43 PM
mo44t
Oct 29, 2005 09:15 PM
