engine harness
Old Mar 26, 2004 | 01:10 AM
jkerkman's Avatar
jkerkman
engine harness
Whe removing the engine from a 94 302 f150, is there any way to unplug the harness and leave the wires on the engine instead of disconnecting every sending unit and fuel injector? (would prefer the solution doesn't involve a hack saw )
Thanks,
Jason
Old Mar 26, 2004 | 06:32 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm not terribly familiar with the harnesses on those years, but I think there is a plug (or plugs) on the drivers side fender that you can disconnect. It runs between the main harness and the harness on the engine, as far as I know. Definitely don't hacksaw the wires, that's just asking for trouble later.
Old Mar 29, 2004 | 09:26 PM
jkerkman's Avatar
jkerkman
Does this come apart? It is on the drivers side of the engine compartment, but it doesn't want to come apart easily. Before I go trying to pry it apart I want to verify that it can.
Thanks
Old Mar 29, 2004 | 10:55 PM
EPNCSU2006's Avatar
EPNCSU2006
That's the one I was thinking about. It should come apart, although I'm not sure how. I know those things can get pretty stuck, so maybe try some wd-40 on it and a lot of side to side wiggling, all while pulling on it. And be careful, you could hurt yourself when it finally decides to let go (I speak from busted knuckle experience ).
Old Mar 30, 2004 | 08:52 AM
lilboysdrivebowties's Avatar
lilboysdrivebowties
isn't there a bolt holding it together? down thru the center or left to right in the picture
Old Mar 30, 2004 | 01:01 PM
EPNCSU2006's Avatar
EPNCSU2006
^ Good call, I bet there is.
Old Mar 30, 2004 | 08:58 PM
jkerkman's Avatar
jkerkman
Yes there is. Thanks for the help guys.
Old Mar 30, 2004 | 09:51 PM
Adrienc9's Avatar
Adrienc9
As a matter of fact it is a 10mm socket size. (I just unplugged mine today!) Then all you should have left is your ground wire.
Tuxedo Scorpion
6.7L Power Stroke Diesel
18
Jun 2, 2012 10:36 PM
duke_boy
May 25, 2011 06:25 PM
RCrawler
15
Apr 13, 2010 01:50 AM
Jason Lewis
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 13, 2005 01:52 PM
JHunter
Jul 7, 2003 11:22 AM
