Strange sounds. Any thoughts?
Old Mar 25, 2004 | 10:36 PM
hdgjr's Avatar
hdgjr
I have been hearing and feeling a strange viberation, which feels like it is coming from behind the cab (possibly rear end), when I take off and turn right or left. I don't really notice it when I start off and go straight nor when I turn when I am up to speed.
Could it possibly be coming from the rear end (limited slip)? I don't know what to think, but I'm afraid something might be binding a little.
Any suggestions????
Harry
Old Mar 26, 2004 | 12:20 PM
JMorton's Avatar
JMorton
Sounds like it could be the clutches in the rear diff. Start by draining and refilling the diff and adding a couple of bottles of friction modifier and see if that helps. If not, you'll have to replace the clutches in the diff to get it cleared up.
Old Mar 26, 2004 | 12:54 PM
Calli's Avatar
Calli
hdgjr, my f-350 has done this since new. Service suggested to make several sharp turns in each direction at low speed. Clears right up. Have to do every few months to keep smooth. I also added bottle of friction modifier. Calli ( just have 40,000 miles though)
Old Mar 26, 2004 | 08:17 PM
hdgjr's Avatar
hdgjr
Thanks, JMortan and Calli. This is the direction my brain was working but didn't have enought experience to trust my instincts. I'll try some of this and see what happens.
Thanks again,
Harry Griffin
Old Mar 31, 2004 | 07:58 AM
jadel's Avatar
jadel
hello there,Ihave a strange noise when I run my 94.5 psd up on rpm say in 3rd gear and then back off the throttle,it sounds like air rushing through somewhere,could it be the exhaust on the turbo or is this normal ,and the sound is not a normal whistle you would normaly here form the turbo.
any info. would be helpful,thanks
adr1
Oct 15, 2022 05:50 AM
EconolineFan
22
Jun 25, 2019 04:18 PM
DinoB
Jul 3, 2016 07:24 AM
samuelmorad
Apr 28, 2015 10:10 AM
Daveyj
Aug 13, 2014 10:54 AM
