Idle Shake Need Help!
Old Mar 25, 2004 | 10:32 PM
FOIWIEN's Avatar
FOIWIEN
I'm having problem with the crank pulley, assuming it is thrown off balanced since my trans was loose for so long. Now that tranny is tightened, crank shake badly causing the whole front end to shake. It is very noticable from looking at the belt in the area below the tensioner pulleys. However, this only happens during neutral idle or coasting. Vibration goes away in drive mode, brakes applied, or under acceleration. I need help ASAP! I'm gonna try to loosen all tranny bolts, then tie it again to balance the mounting angle.
Any advise?!!
hollenjoe
Jan 17, 2014 11:06 AM
jeffreyt
28
Sep 19, 2013 09:25 PM
rastus3
Jun 23, 2013 01:27 AM
Superduty.pride
Oct 21, 2011 12:43 AM
