Help me quit smoking
Old Mar 25, 2004 | 09:29 PM
96 Canucklehead's Avatar
96 Canucklehead
I've noticed my 96 PSD smoking more during the morning warm-up, and God help the poor sap following me when I start grabbing gears on the highway to work (prior to it reaching running temperature). The colour is a bluish-white and I use a local favorite fuel additive. What is the significance of the smoke, if any, and how can I reduce it, if necessary.
Thanks in advance
Old Mar 25, 2004 | 09:33 PM
johnsdiesel's Avatar
johnsdiesel
Sounds like the injector o-rings might need to be replaced. Probably not a coolant leak.
Old Mar 25, 2004 | 09:35 PM
96 Canucklehead
Is it a relatively costly repair to have the o-rings replaced?
Old Mar 25, 2004 | 09:38 PM
johnsdiesel
Parts will run about $80-100. The main cost of having someone else do it is the labor. It takes a while to do. While you have the valve covers off you also should replace the glow plugs.
Old Mar 25, 2004 | 09:49 PM
96 Canucklehead
Is the cost you estimated for each injector or for all eight?
Old Mar 25, 2004 | 09:58 PM
johnsdiesel
Yes. Kits are a little more than $10/injector.
Old Mar 25, 2004 | 10:14 PM
jamesbfishin's Avatar
jamesbfishin
Could the injector o-rings also cause a drop in mileage and a slight feeling of being sluggish?
Old Mar 25, 2004 | 10:21 PM
johnsdiesel
Yes. It also is accompanied by oil consumption. Also, if your fuel filter is black or darker than usual that's a good sign.
Old Mar 25, 2004 | 10:29 PM
jamesbfishin
Fuel in the bowl was normal in color, filter was not black, but relatively clean and had a slight redish tinge to it. Any thoughts.
Sorry Canucklehead I didn't mean to hijack your thread.
Old Mar 25, 2004 | 10:30 PM
johnsdiesel
How many miles on your truck? I'm trying to explain a lot of the symptoms, you may not have them all.
Old Mar 25, 2004 | 10:32 PM
jamesbfishin
About 120000
Old Mar 25, 2004 | 10:33 PM
johnsdiesel
If they've never been changes you're probably due. Do you have white exhaust at startup?
Old Mar 25, 2004 | 10:36 PM
jamesbfishin
They have never been done. The exhaust is usually a mix of blue and white, the blue I am to assume oil burn, but disappears at normal opperating temp.
Old Mar 25, 2004 | 10:42 PM
johnsdiesel
Sounds like you've found your problem. Before you fix, make sure you're not loosing any coolant. Blue exhaust can also be a coolant leak although it is unlikely.
Old Mar 25, 2004 | 10:53 PM
jamesbfishin
Coolant levels are perfect, Would something like this be fixable for someone that has great hand eye coordination (I am a cabinet-maker by trade) but not quite a diesel mech? Thank you kindly for your input, it's appreciated.
