Replacement Floor Pans
Old Mar 25, 2004 | 05:47 PM
Flying_Elvis's Avatar
Flying_Elvis
Question for you. I am restoring my '74 F-250, and need to replace my floor pans. The problem spots are right near the door edges and after looking at the pictures of the replacement fllor pans in NPD and LMC Truck, I'm not sure if the replacements will cover that far over, has anyone ordered these, and will they cover it? Thanks.
Old Mar 26, 2004 | 06:44 AM
kokopelli's Avatar
kokopelli
try jc whitney. they have a piece that covers the entire door sill for like 15 bucks.
Old Mar 26, 2004 | 12:08 PM
dfisher1's Avatar
dfisher1
Elvis,
If the floor pan is just rusted out around the door sill, this should just be a straight flat section of sheet metal. Do you plan on replacing the whole pan?
It is not very easy to remove the whole pan due to spot welds and structural steel that supports the pan. I would reccommend just cutting and patching the small area you describe.
Give me some details, and I'll fill you in on the nitty gritty of this repair.
KingFisher
Old Mar 26, 2004 | 01:41 PM
Flying_Elvis
KingFisher,
I'm not too sure of all of the specifics, as the truck is in Spokane, and I am in western Washington in the Navy. I have to replace most of the pan due to rust in the foot area, so I was planning to get the replacement parts from National Parts Depot, but I wasn't sure how much it covers. I think I may put the pans in, and then patch over to the sills if it still needs it. Thanks for the help.
Old Mar 26, 2004 | 06:51 PM
Mil1ion's Avatar
Mil1ion
Why not buy them from this FREE web site http://www.motorhaven.com/customer/home.php?cat=145
or our sponsors ?
Old Mar 30, 2004 | 11:39 AM
Bleed Blue's Avatar
Bleed Blue
I just finished putting a passenger side floorpan in my 78 F150. I can't stress enough that the Motorhaven part was definitely the way to go. The sheetmetal itself is enough to cover under the kickplate. The fun part was welding to the cab mount. I'm glad that project is over!
fitzmotor
Mar 6, 2022 08:37 AM
the body
13
Aug 29, 2015 10:40 PM
LesPaul
Aug 12, 2015 10:05 PM
78F-250Lariat
Dec 4, 2014 01:18 PM
LesPaul
Jun 24, 2008 02:45 PM
