Spuddering motor
Old Mar 26, 2004 | 04:58 PM
EPNCSU2006's Avatar
EPNCSU2006
You can't change the firing order without a different cam. Both firing orders work on the same small block bottom end - you can put a 351 cam or a 302 cam in a 302, and change nothing else internally, and it will work. The only difference in the mass air swap that MustangGT did is the injector firing order in the computer.
Old Mar 27, 2004 | 11:22 AM
Talyn's Avatar
Talyn
Thats right emcu (jeez where you guys come up with your names!)
just fireing gas at the wrong times. =(
Old Mar 27, 2004 | 04:40 PM
MustangGT221's Avatar
MustangGT221
Originally Posted by lexluthr69
Just put your plug wires back to the non-HO firing order and fire it up. You should immediately notice correct firing, but MABYE with a slightly rough idle.
I put the plugs back as I said and it runs ok. You were correct, after some seat time I noticed the idle was a little rough. I'm going to swap the pins on the computer connector to get it right. Even as it is now it runs smooth and has more power then before, can't wait til the SEFI is working correctly.
Talyn, ya don't have to change the crank/pistons to change firing order.
Old Mar 27, 2004 | 04:43 PM
EPNCSU2006's Avatar
EPNCSU2006
It should feel a whole lot better when you get the injectors right. The throttle response will be incredible.
Eric Poe North Carolina State University class of 2006 (if all goes well).
Old Mar 27, 2004 | 07:36 PM
brown 4x4's Avatar
brown 4x4
Why did you even have to change firing orders? All '95 302's I've seen, MAF or SD, had the 13726548 order. Yours was 15426378?
Old Mar 27, 2004 | 08:11 PM
MustangGT221
The stock truck order is 15426378, the 13726548 is for HO 5.0 motors or 5.8L motors.
Old Mar 29, 2004 | 04:07 PM
MustangGT221
Well I took the connector off the computer to have a look-see. It doesn't appear that I can just pull the pin out and swap the pins (this is the MAF kit's connector I'm looking at). There are two groups of wires going to the connector. One appears to be for the MAF sensor, and the other for the injectors. The wires going to the injectors have a piece of tape on them that tell you what pin # it is, so I know which wires go for which pin #. The only thing I think I can do is cut the 3-5 injector wire at the beginning of the harness and swap them, solder them, and heat shink them. I don't know if I want to do this not knowing if its going to work correctly, and when I'm going to have to swap this back in a few months. It runs ok but the idle is a little weird. It runs fine for a little while but after a minute or so the idle goes a little lower in RPM and it is a little rough. I can live with it for now though.
Old Mar 29, 2004 | 05:29 PM
Talyn's Avatar
Talyn
if gas fireing in at wrong times though. you got gas setting in the chamber waiting to be fired on some pistons. Thats why its idleing rough.
Old Mar 29, 2004 | 06:50 PM
EPNCSU2006's Avatar
EPNCSU2006
Do you have a picture of the MAF overlay harness? I still think you should be able to swap pins in that thing.
Old Mar 29, 2004 | 10:39 PM
MustangGT221
I can take one when I get a chance. Basically it's a two sided plug. One end goes into the computer and you plug the original truck's harness into that. So basically the kit's connector is sandwiched between the computer and the original harness.
Old Mar 29, 2004 | 10:51 PM
EPNCSU2006's Avatar
EPNCSU2006
I wish I knew how to get those things moved around, but I'm not familiar with that sandwich adapter for the motorsports conversion. It might be best to just drive it like this for the short time until you get the new motor up and going so you can avoid cutting and soldering the wires twice. It shouldn't be any problem doing that as long as you make a good connection, but if you're gonna have to turn around and put it right back like it was, it might be better to just leave it be for now.
Old Mar 30, 2004 | 10:27 AM
Talyn's Avatar
Talyn
I'd leave it too.
Soldering wires taht are important like that is just a pain, and could cause problems in the future.
Old Mar 30, 2004 | 02:17 PM
  #28
lexluthr69's Avatar
lexluthr69
Eric, weren't you part of that conversation we had with TripnDrag about the swapping of the injector wires around? Talking about how he's running the HO plug firing order with the regular 5.0L injector order in SEFI. Whereas, I cut and spliced/soldered mine to match HO plug order with HO injector order. I did the cut and splice, but I did mine knowing that I wouldn't be going back to the old firing order.
Basically the only place you'll see a difference is in your idle and out the tailpipe. Once you get back to true SEFI and both firing orders are in time, your emissions will be cleaner and your idle will smooth out. The FRPP tech guys told me over the phone that once you hit 2500RPM it doesn't really matter as the injectors are firing at such an extreme rate that there's not enough time for the fuel to just "sit" there.
If you plan to run it later with the order it's in now, just leave it be, and you'll be fine.
Ringwood1
25
May 29, 2026 03:19 PM
asmith6
Feb 14, 2024 09:18 AM
silar
May 21, 2016 09:48 PM
lisagoud
Apr 7, 2015 05:38 PM
umdstang
Oct 19, 2004 06:18 PM
