fuel injection problems
Old Mar 31, 2015 | 02:11 PM
lisagoud's Avatar
lisagoud
Okay..1986 F250 5.0 motor 2 years old (former 1994 roller cam with 1986 intae on it to be compatibile)..changed out the computer, IAC, plugs, wires, and distributor. Engine is still doing mighty strange things like reving up to 2000 up starting and can't do anything but shut it down. Then it starts to run correctly and then stalls out. Changed fuel filter also. Wondering about the throttle body if could swap it our for a mustang BBK 65mm.EEC was a 1987 Mustang 5.0 when got the truck and it ran great (motor is an ho cam so the firing order is like a 5.8). any more suggestions like going to a 65mm and swapout the EGR to the correct size as well?
Old Mar 31, 2015 | 02:19 PM
Franklin2's Avatar
Franklin2
What is the computer telling you? Have you read the codes? Are you running a 86 computer or a 1994 computer and wiring?
Old Mar 31, 2015 | 04:19 PM
lisagoud's Avatar
lisagoud
EEC
19867 5.0 mustang computer...no codes shown
Old Apr 1, 2015 | 02:24 PM
Franklin2's Avatar
Franklin2
You should have at least one code if everything is normal.
Old Apr 7, 2015 | 05:38 PM
lisagoud's Avatar
lisagoud
tied the problem down to the old original throttle body...changing it out now.
SCRebel
Jan 2, 2012 09:39 PM
cljimmy72
24
Nov 22, 2009 04:33 PM
Trevor1
29
Nov 19, 2008 10:53 PM
Richiemech
Dec 24, 2006 07:46 PM
gquinn8516
May 31, 2003 04:51 PM
