Starter interrupt
Old Mar 24, 2004 | 05:51 PM
RingwoodSid's Avatar
RingwoodSid
Starter interrupt
Hi
I have an antitheft interrupt circuit that I'm installing in a 2004 F250 Diesel, automatic. I have the option to interupt 3 circuts.
I'm looking for some ideas on which 3 electrical circuts to disable.
Thanks,
Sid
Old Mar 24, 2004 | 07:22 PM
Franklin2's Avatar
Franklin2
Fuel pump relay coil
Small wire going to the starter relay
If you have a starter with the solenoid built in, interrupting the solenoid power will work.
Old Mar 25, 2004 | 04:23 AM
RingwoodSid
Thanks,
Any ideas on where I can get a wiring diagram for this truck?
Sid
Old Mar 25, 2004 | 09:48 PM
Mil1ion's Avatar
Mil1ion
You don't need one.
Just interupt the wire that goes from the Ignition to the starter relay with a keyed switch.
The best location is near the relay itself with the switch somewhere that is in-accessible from the cab.
Mine is in the door frame where the dome light switch is.
Old Mar 26, 2004 | 04:15 AM
RingwoodSid
Thanks
I'll have to get under the hood and look around. I just picked up the truck
and don't have any idea where anything is located. Is there an underhood box with
all the relays? Are they marked?
Thanks
Old Mar 26, 2004 | 11:40 AM
Mil1ion's Avatar
Mil1ion
Follow the wire(s) to the starter and see if there is a relay attached to the.
I'm trying to help but I haven't really spent any time with Newr trucks.
SeaCarr
Aug 29, 2021 09:14 PM
N2S3
13
Feb 8, 2017 11:15 PM
Rick Standifer
Aug 26, 2016 08:16 PM
pbjosh
56
Feb 23, 2015 08:29 PM
79f150
23
Aug 15, 2013 10:28 AM
