I have an antitheft interrupt circuit that I'm installing in a 2004 F250 Diesel, automatic. I have the option to interupt 3 circuts.
I'm looking for some ideas on which 3 electrical circuts to disable.
You don't need one.
Just interupt the wire that goes from the Ignition to the starter relay with a keyed switch.
The best location is near the relay itself with the switch somewhere that is in-accessible from the cab.
Mine is in the door frame where the dome light switch is.
Thanks
I'll have to get under the hood and look around. I just picked up the truck
and don't have any idea where anything is located. Is there an underhood box with
all the relays? Are they marked?
