Coil On Plug (COP) Testing
Old Mar 24, 2004 | 09:40 AM
jgrm2's Avatar
jgrm2
I was awarded the P0308 code last night after my 2001 4.6L began to miss and the "Check Engine Light" illuminated. This code represents a misfire in cylinder #8. After performing a search on this board, it seems that the COP is a likely culprit.
Is there a way to test these coils before dropping $100+? I know I can replace the spark plug first to rule it out, but am wondering if there these COPs can be tested (i.e., resistance test) like the old coils. If so, what is the procedure?
Thanks,
Jeff
Old Mar 24, 2004 | 10:03 AM
snlsand's Avatar
snlsand
I have the 5.4 and I was told you could'nt test them so last night I started replacing the coils and plugs,WOW what a pain so far I've got 5 out of 8 done. but I did find a good price at NAPA for $41.00 each.
Old Mar 24, 2004 | 10:58 AM
jgrm2's Avatar
jgrm2
Thanks for that tip. I was told by Autozone that the coils were a dealer-exclusive item.
-Jeff
Old Mar 24, 2004 | 07:27 PM
Garfield's Avatar
Garfield
Lightbulb COP Testing Can Be Done
They sell a node tester for COP testing , Also with a simple multimeter check the (+) terminal connector to the spark boot inside connection for a 5.2 - 5.6 resistance
Old Nov 29, 2020 | 02:05 AM
Popzhd's Avatar
Popzhd
Coil to plug connection?
Does the wire/spring actually slip onto the spark plug tip, or does it just sit above the spark plug and not snap onto the spark plug tip?🤔
Old Nov 29, 2020 | 05:17 AM
JWA's Avatar
JWA
The spring is directly connected or attached to both the COP and the spark plug electrode---its the only way the high voltage spark gets to the actual spark plug.
Old Dec 2, 2020 | 12:37 AM
Maxduty's Avatar
Maxduty
Since this necro thread got bumped up. If anyone has this problem again. Just swap it into another position. If the misfire moves, it's bad.
Old Dec 2, 2020 | 01:06 AM
Popzhd's Avatar
Popzhd
Got rid of the misfire codes, but still have PO171, PO174, AND 405 and rough idle a little better but not like it should be! I don't know what to do or what the problem could be. Have replaced: 8 plugs, 8 coils, cats, muffler, exhaust, 02 sensors, cleaned throttle body and intake manifold! Cleaned MAF sensor too! I'm lost, need help and desperately to say the least!
xpedition
Jun 5, 2015 02:40 PM
makthenif
1997 - 2003 F150
Apr 24, 2014 08:49 AM
jdhudall
1997 - 2003 F150
15
Mar 21, 2009 07:27 AM
jgrm2
1997 - 2003 F150
Mar 24, 2004 11:22 AM
jgrm2
3.8 & 4.2L V6
Mar 24, 2004 09:41 AM
