Sponsored by: Real Truck
synchros????
Old May 17, 2000 | 08:31 PM
4rdgasm's Avatar
4rdgasm
synchros????
My dealer was trying to tell me that my synchros went because I rest my hand on the 5spd stick, when I drive. I thought the synchros were only used when shifting.
Old May 17, 2000 | 10:04 PM
run8's Avatar
run8
synchros????
Mine went.. Sitting at the dealer, waiting for parts, while I need my *dependable* Ford to get from Missouri to Indiana this weekend..
And I NEVER rest my hand on the stick because of it's awkward position!
Y2K SD CC 4x4
Old May 18, 2000 | 05:38 AM
Lou19's Avatar
Lou19
synchros????
What you're doing if forcing the shift yoke against the spinning/engaged gear,and the synchro is in the middle. Without the synchro,every gear would grind like 1st/granny gear. The synchro acts like a brake to slow the free gear to match the speed of the power gear. When the two gears speed are sycronized(thus the name),their teeth mesh quitely. I have an auto in my truck, but I am sure the dealer is actually right on this one. May have to get an armrest in the truck to prevent this premature wear. Hope the repair cost is reasonable. Good luck.
Lou (2000 F250SD CC Lariat 4x4 V10)
Old May 18, 2000 | 03:59 PM
run8's Avatar
run8
synchros????
Lou,
That doesn't change the fact that I, in fact, do not rest my hand on the stick. My dealer said mine was far from the only one they have swapped out synchros on.
Yes, resting your hand on the stick does cause the problems you mention, but it seems to be a different problem..
Run 8
Y2K SD CC 4x4
Old May 19, 2000 | 05:43 AM
Lou19's Avatar
Lou19
synchros????
Well,in that case,I would suspect a lubrication problem based on premature failure.The synchros are wearable but rely on lubrication to limit the wear.They get almost all of their wear during a shift - when friction is highest.If they are engaging nearly dry,that will eat them up quick.I wonder what manual trans the 450 & 550 get? They have to be failing at a higher rate.Good luck.
Old May 20, 2000 | 09:29 PM
4rdgasm's Avatar
4rdgasm
synchros????
thanks guys, that gives me the info that i needed.
Old May 22, 2000 | 12:25 PM
midwaymike's Avatar
midwaymike
synchros????
TireJockey
Feb 19, 2013 04:46 PM
akhunter85
Jul 16, 2012 08:16 PM
CaptainIPSC
Sep 1, 2009 09:54 PM
Zigman
3.0L V6
Aug 19, 2003 09:21 PM
