Redline oil
Old Feb 16, 2013 | 03:40 PM
TireJockey's Avatar
TireJockey
Redline oil
Okay so ive heard and read in a bunch of different places that redline should be used when synchros start going out. Well, my 1 to 2nd synchros is in pretty bad shape and now 3rd is starting to grind every once in a while. I want to save these before i abosulutley have to rebuild my tranny, as i really dont have the budget for that.
My question is, exactly what type of redline should i get for my tranny, and exactly how does redline help sychros? Does it have to do with the fact that synchros are basically friction plates? And redline has a high quallity friction modifier? Or am i completely off base here? i have the Zf-47 if it matters.
Old Feb 16, 2013 | 04:01 PM
pjwoolw's Avatar
pjwoolw
Well if your synchros are in fact damaged no fluid is going to fix that. I would drain the fluid and see what comes out with the fluid. If your in a relatively warm climate I would run the Red Line MTL. Otherwise the D4 ATF. There are no friction modifiers involved to my knowledge.
Old Feb 16, 2013 | 04:09 PM
richdawg's Avatar
richdawg
This is what I used in my trans, but I don't know if it will help with the synchros
Old Feb 16, 2013 | 04:57 PM
TireJockey's Avatar
TireJockey
I have just heard from a lot of people that it will help with bad synchros
Old Feb 19, 2013 | 03:26 PM
BuckHammer's Avatar
BuckHammer
Yeah, I don't know about that.
Old Feb 19, 2013 | 04:46 PM
Diesel_Brad's Avatar
Diesel_Brad
WTF. Where do half my posts go?
The Redline MTL is Highly praised to help notchy syncros.
I tried it in my 97, but did not work. I ended up spending $450 to rebuild the trans. Now it shift like butter
71dusterdan
Oct 22, 2009 10:48 AM
Tomcat7742
Oil & Lubrication
Jan 23, 2009 03:57 PM
RobertJohn
Dec 22, 2006 07:12 PM
omni
24
Jul 29, 2004 11:17 PM
crossf-150
Jan 26, 2004 05:09 PM
