Sponsored by: Real Truck
CB antennae mount
Old May 30, 2000 | 11:49 AM
cwolfe's Avatar
cwolfe
CB antennae mount
Where is the best location to mount a CB antennae on a 2000 SD? I current have a Wilson 5000 and I am wondering what type of mounting system to use.
CWolfe
Old May 30, 2000 | 12:54 PM
mondogeek's Avatar
mondogeek
CB antennae mount
I had this same dilema awhile back. Wanted to go with mirror mounts, but at the time, I couldn't find anything that worked with the uniquely shaped mirror arm on the SDs.
I currently use a magnet-mount on the roof, with a short "cell-phone look" antennae, and the wire going in thru the back sliding window. A disadvantage is with the mag-mounts, you might get some paint damage or rather an "unfaded" spot under the mount, if you leave it on all the time. Might not be an issue to you because the roof is so high (on the 4x4) that it would be practically unnoticable. I don't use mine enough to where that would be a problem. There's a highth/clearence issue to consider too, with a roof mount.
Another (and perhaps the "best") option is a hood mounting bracket. It's kinda "L" shaped, and screws into the sheet-metal under the crack between the hood and fender. With the antennae off, you'd still see an unobtrusive little mounting flange poking out. Yes, you have to drill holes, but even if you remove it later, they're hidden under the hood. But, that was enough to make me not want to do it; you might feel differently though. I don't know how you'd best run the wire; perhaps in thru the door jamb (like you would with a mirror-mount), or under the hood & thru the firewall?
Good luck, whichever way you go.
>a 2000 SD? I
>use.
>CWolfe
Old May 30, 2000 | 07:06 PM
Steve R's Avatar
Steve R
CB antennae mount
I'm a ham radio operator, KA5MTE. I have run into the same dilemma. I have decided to punch a hole in the roof of my 99 F250 crewcab. There are several reasons for doing so.
1. It puts the antenna at the highest point on the vehicle, making for a clear and equally dispersed signal in all directions.
2. By punching a hole in the roof, I get a good ground for the antenna to react against.
If you do this, you need to make sure that the antenna that you install is removable, just in case you want to park it in a garage. The other option is the "L" bracket that attaches on the inner side of the hood. I have used one of those in the past and it worked sufficiently well. It will give you a good ground to work against, but the signal is blocked by the cab of the vehicle.
Good luck,
Steve R
'99 F250 CC 5.4L LB 4x2
Old May 31, 2000 | 03:23 PM
Howard's Avatar
Howard
CB antennae mount
ManfredVonRichtofen
1978 - 1996 Big Bronco
15
Jan 9, 2017 11:30 AM
strokeorcroak
15
Dec 12, 2010 09:23 PM
bubbasz1
Dec 13, 2009 07:37 PM
rpenterics
Jan 1, 2009 05:03 PM
taxabel
66
Oct 10, 2004 12:59 AM
