Predator ????
Old Mar 23, 2004 | 05:12 PM
billyboy's Avatar
billyboy
Predator ????
I have the predator installed on the 65hp setting. Is it normal for it to shift very hard when cold? If not what can I do to fix it. I only notice it when it’s cold, so that is probable the problem. If anyone has any input, that would be great. Other then the hard shifting, that predator rocks.
Old Mar 23, 2004 | 06:12 PM
Hayapower!'s Avatar
Hayapower!
How long has the new tune been installed.. It will take up to 5 warm up/driving cycles, for the PCM/OBDII system to re-learn its/your shift strategy.. Mine shifts "a little" solid when cold, but normal when warm..
Old Mar 24, 2004 | 12:44 AM
FTE Ken's Avatar
FTE Ken
This is perfectly normal due to the line pressure increase the Predator gives. When the tranny is cold, the fluid is thicker so you're more likely to see the issue, but its far better than the erractic shifts during heavy throttle prior to the two most recent updates.
Old Mar 24, 2004 | 05:58 AM
SBV45's Avatar
SBV45
I plan on ordering a Predator today. I just want to recover the mileage and performance that I once had. I can't seem to find it but what does Diablo Sports say about compatibility with furure flashes from Ford? If I load the 65HP program and get let's say 3 mpg increase will I expect to see similare increases in what Ford does in the future?
Old Mar 24, 2004 | 06:48 AM
jdadamsjr's Avatar
jdadamsjr
My Ex actually shifted "more crisply" when cold before I got the predator...
Lot's of fluid to warm up down there before it is at the correct operating temp...
(actually fun to chirp the tires with moderate accel. in the morning )
And since the predator can be updated online, I would think:
1) Diablo can updated the predator to account for changes..
2) any changes Ford makes will just be saved within the Predator when it replaces the Ford tune...
And besides, I presume the Predator is a completely new "program" to control the computers on your truck....
independent of the ford program...
not an addition to the ford programs...
which is dependent on what the ford program does...
This should be a bigger concern for all the modules taht are added after the computers.. since they do modify the params of the ford program rather than replace it...
But don't wait due to this concern - get the predator NOW so u can enjoy the POWER and mpg increase !!!
Old Mar 26, 2004 | 05:59 AM
SBV45's Avatar
SBV45
I got my Predator yesterday. I uploaded the 65HP program. All I can say is you can feel the difference the very first time you touch the accelerator.
This thing flies. After driving it about 100 miles, there was a Ford 350 with a 7.3 tricked up that jumped on it coming away from a traffice light. I went from 0 to 45 while the other was going about 25. I was absolutely surprised!
Where do you get support for the Predator? I have a few questions. I have a P0600 PCM KAM error and a P1000 error OBDII test incomplete. I think the OBD error was from at the end of the upload. It says to disconnect the tuner and then has "continue". Well if you disconnect before continuing, goodbye.
Old Mar 26, 2004 | 06:54 AM
jdadamsjr's Avatar
jdadamsjr
NO,
if it tells you do disconnect... it's done....
Go thru the cycle again now that you are familiar with it...
set it back to stock, clear all the codes, and reinstall...
when you first boot the predator... the KROS logo comes up and then it will tell u the release number of the software... if the last 3 characters are not r34... then you can get the latest version from the diablo website @ w<!-- -->ww.di<!-- -->ablo.com
Old Mar 26, 2004 | 01:03 PM
SBV45's Avatar
SBV45
Thanks for the info. I uploaded the original factory tune and got no codes. I then uploaded the 65HP tune and got no codes.
I noticed in addition to the three tunes offered on the Predator, a Factory HP. No mention of it in the manual. Anybody know what it is?
Old Mar 26, 2004 | 02:50 PM
taztruck's Avatar
taztruck
Factory HP
"Factory HP" is the title for the original factory flash that the Predator grabbed from the PCM and tranny. It retains these codes so you can restore them back to stock before Ford services it. Note that if the truck gets flashed when in for service, then you use the Predator to modify the truck, the latest codes from the truck are loaded into the Predator's memory. What I do not know is what would happen if you try and restore the "Factory HP" tune into a newly reflashed truck, would it error out or would you return your truck to pre-flash status? Maybe someone has tried this.
Old Mar 26, 2004 | 04:22 PM
SBV45's Avatar
SBV45
I think the object is to upload the factory program from thr tunerwhich resets the tuner. Then when the truck gets flashed, the next time you connect to reupload your performance tune, it would download the latest flash as the factory HP.
Old Mar 26, 2004 | 09:03 PM
Choctaw Bob's Avatar
Choctaw Bob
The Factory HP tune is your stock flash plus the transmission mods.
bigfoot7180
Nov 26, 2012 12:53 PM
josh04hdf250
Apr 15, 2008 09:21 PM
s2gots
All Things Towing
Sep 17, 2007 12:28 AM
TWellmann
2004 - 2008 F150
13
Feb 6, 2006 11:44 PM
dirtroaddevil
Oct 27, 2003 07:10 PM
