Injector swap
Old Mar 23, 2004 | 01:29 PM
93superflare's Avatar
93superflare
Injector swap
I am considering changing out my injectors... I've got two that are not working properly and I want a performance mod.
How do I find out what the fuel delivery rating is of the stock injectors?
I have read (on a performance/mpg website) that 41# is the optimum for a '96 big block application, but I have a '93 5.0 Speed Density EFI, EEC-IV, E40D electronic overdrive.
Anyone have any suggestions on my best options... obviously, I will be chipping it to get the correct computer response, but what about the fuel pump? Can I tweak it a little to adjust the fuel flow? If so, How?
I will also be installing a twin 61mm Throttle body and a 1" fuel plenum/intake spacer to even out air flow mixture and provide more low-end torque. Later, gt40P heads, but that's a completely different nightmare.
Anyone?
Old Mar 23, 2004 | 04:38 PM
ferguson777's Avatar
ferguson777
You might want to take this question over to the performance engine forum on this site. You'll get more people seeing it there.
With a speed density EFI system I think you can pretty well froget about a larger throttle body or larger injectors.... Smarter people than me will likely tell you that as well.....
Later,
Old Mar 24, 2004 | 12:32 AM
EPNCSU2006's Avatar
EPNCSU2006
Larger throttle body is do-able, but stick with stock injectors unless you want to get a computer chip. The stock injectors are 19lb/hr (orange tops), which supports around 300 horsepower. The fuel pump doesn't flow very much, but should be good for as much as the 19lb injectors are good for (horsepower wise).
Old Mar 24, 2004 | 10:50 AM
93superflare
Okay, thanks guys, but just for the sake of argument, if I decided to put say... 24# injectors in, what color are they and how would I go about tweaking the fuel pump?
My longer term plans include a cylinder rebore with a stroker re-build and cam bump-up.
I definitely will be adding a chip.
Old Mar 24, 2004 | 11:34 AM
EPNCSU2006's Avatar
EPNCSU2006
24lb/hr injectors are blue tops. I'd say that instead of tweaking the fuel pump, get a new one with a higher flow rating, say around 155 lph or so. You'd need one for each tank if you have dual tanks. With a stroker, larger injectors would probably be a good idea, and since you plan on getting a chip, make sure the chip maker knows that you have bigger injectors so they can program the chip to use the injectors correctly.
Old Mar 24, 2004 | 11:42 AM
93superflare
Thanks... nice to have all the pieces of the puzzle before I try puttin' it together, ya know?
DHamSTER
Dec 6, 2013 10:09 AM
PeterTheWolf
2004 - 2008 F150
Apr 26, 2012 03:57 PM
lvin4jc
Apr 18, 2012 11:41 PM
dieselsanddogs
Mar 3, 2011 08:31 PM
greystreak92
1978 - 1996 Big Bronco
May 21, 2003 02:49 PM
