FE Block Numbers
Can someone decode the block number on my motor. It is C8MEA.
Thanks |
its a 1968 block
Not necessarly a 68 block. Only the date code will tell you that. A C8ME could have been cast in 69 or 70 too. My book list's it as a 428CJ block, but these books have been known to be wrong too.
1968 428cj block out of a car. atleast thats what the book says
they are junk! you should send it to me and i get you a 390 instead!
It's either a 428 block, or a 330HD block, or a 361 / 391 FT block. Casting molds were probably made in 1968 for Mercury applications, but it could have been cast later than that for a variety of uses. Since it shares numbers with FT blocks, it's probably a good strong thick cylinder wall block.
I know that this is a very old thread but..... can this be safely bored out to a 428 bore without sonic checking?
Originally Posted by Fomoko1
(Post 12668930)
I`m referring to specifically a 360 truck block like a C8ME, I know that the 390 blocks need to be checked. Put a different way are all the 360/390 blocks from cars and light trucks all the same for cylinder wall thickness?
(Post 12669088)
